I have to produce tangible work, I just make sure I'm the only one that can do it.... Wana fire me, try it let's see you run you business muhahaa :devil:
See how your post count diminishes as you marry a Taylor Swift look a like (because we both know you will not have a chance with the genuine Taylor) , spit kids (not skids), have an intense full-time job and a mortgage.
Totally have a chance, she just hasn't seen my guitar skills yet
Wow. So much happens when I turn my phone off for a few hours.
Seems as though the "new generation" of SAU qlders have a lot to learn.
Looks like there's a lot of history and a lot of knowledge amongst you guys.
Anna doesn't seriously think that I'm a feggit does she? :( also, shame on everyone else for not recognising "impact blue" wankers.
Who's coming out drinking on the 12th?
me, no kids (yet), and my wife has more curves than taylor swift.
then again, the 1/4 mile has more curves than taylor....
still dont know impact blue, but im new here, so cut me some slack.
in 5 years, go off at me for bot knowing any of you guys.
Don't dis my Taylor, she came over the pa at willowbank the other day and tony threatened to break my knee caps if i kept dancing lol
Lol.......would love to meet you someday Luke. I'm sure your wife is wonderful as well (no joke).
Tony. There is a lot of history here, and it's important to harness as much of it as possible.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
