for a week now.farking love it.heaaaaps better off boost.crazy when its on.but as stated, cuts at 6k.still getting used to the dog box.ok going up through the gears, still learning down gearing.
So want this.............so very much this.........
Really happy your enjoying it Luke. Post some pics up of it if you can.......I'm an engine bay perv so post that up :)
Mr ants what's cracking mate?Just took one of the skyline crew for a run in the abomination. He liked it lol
Came back from tip. Got rid of tonnes of crap from the garage inc old engine fan and interior floor matts from the skyline.
Making more room for the GTR when she comes back to me.
Also did the groceries straight after which was a mission with my 3yo daughter.
Lol re joy ride in A-bomb........you should start charging for rides.
Did you make sure you flushed out the radiator and put new coolant in it :P
No I didn't but I topped it up with coolant and added more water because the place she gets it serviced is sh*t! They checked nothing
Luke, your car is really hot mate. I love it ;)
Here is a pic of what my mech sent me yesterday
she is basically ready to be bolted back. I need to drop off Nismo Twin Plate Clutch and other drivetrain bits now. I also need to find some pipes to replace the a/f meters.
looking good.
Would bang.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
