GTiR use timing chains. and ther will be no crank over at all if the valves are hitting the piston.. i might come have a look wher u located..?
the timing chain is alot stronger (opinionated) than T belts. and dont need changing.
check how much oil u have. perhaps ur mechanic forgot to tighten the sump plug and ur oil leaked out.
sounds like its cranking over. so im guessing its gonna be no spark. they check ur ignitor.? get a compression test
all cars run shit when cold. its just they run a different map and have the auto choke on. u shouldnt drive a car hard untill it reaches operating temps.
No offence but you almost seem as though you have as much mechanical knowledge as the rest of SAU. Since when does an EFI car have a choke?
And whose opinion that a timing chain wouldn't be stronger than a belt?
Sif a chain would be weaker than a belt. I've only ever heard of one timing chain breaking before. Usually people blame the chain for being noisy when it's actually the tensioner that's broken or a guide. Anyway, off topic.
You are, however, possibly on the right track with spark. That would make sense with fuel coating spark plugs. Do you have a spark tester?
don't take this the wrong way, but all that to achieve 300rwkw and not to really use it?
like you said, there's a valid reason: owning too many cars and hardly driving it.
and i'm speaking generally here; but doesn't anyone plan things anymore?
why i want the skyline?
what i want to do with the skyline?
how am i going to achieve the above?
just seems a shame that's all. alot of hard work and no enjoyment.
Yeah Ive had the car for 3 years, I bought it thinking id have it for 12 months like my other skylines.
But it grew on me, but i need to see as life has changed rapidlly for me in the past 6 months.
So in short yes I did think about this, Ive had 3 years with the car, yes it only reached its goal in the past 6 months, but now life has changed and I dont use it nor see it anymore. So I may as well not have it at all.
Its sad but its time to go and move onto something else... Im not giving up the thrill of performance cars/bikes, I still have the S15 and the GSXR...
lol yeah, the new owner was roasted on cb for trying to race someone who was driving a corolla or something and then having a mate moon him out the window when he refused....sounds like an A Class skyline owner!
All skyline owners are jack ass;s
Guest
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
