hmm liz how bout a sr20 powered mx5 ? cool and quick :)
too expensive
if it's a track car, it needs to be cheap to set up and cheap to run and repair!
so s13 with s14 engine and s15 brakes.. i reckon it's a good combo
sic! ur a champ :thumbsup:
dont spose u know, what are trust t618z's rated to? are they 800hp like the gt-rs's?
no idea, for all my turbo needs I talk to slide
so your forcing your dreams onto me :thumbsup: you sound like a bad father. "you'll do it because i say so!" :)
the thing with the 20btt is that it has 224kw and 401nm of torque stock! also bear in mind that its making that torque from 2500rpm upto 5500rpm i believe. no sr could match that. now change the turbo's up the boost to around 15psi each and your going to have a very very quick car with almost no work involved at all! meanwhile the little sr20 is still trying to make the same power with the same mods.
too expensive
its going to be a hill climb car. s13 are too heavy for what i want. mx-5 is lighter and same price range
edit: troy, the coilovers i want for it are 3k for the set. tarmac rally spec ones from tein, have to be brought over from japan
Edited by lilmike86
yes but i remeber helping a mate do a 13b one and he had al sorts of problems in having to move the steering and cost him heaps.
nah its cool I thik i may of found a mx5 for sale they want 7k it has a new top and batt and is on the goldy :thumbsup: and its white :)
nah its cool I thik i may of found a mx5 for sale they want 7k it has a new top and batt and is on the goldy :) and its white :)
from what bullet told me there isnt a lot needed other than the mounts and driveline (i could be mistaken)
sounds good, but i have to restrain myself from looking for one just yet, not till insurance pay me. they could take months for all i know :) i want the car now, but i cant yet :thumbsup:
but you didn't answer my question who makes that kit?
you never asked me that question :thumbsup: the body kit - GARAGE VARY, engine mounts - Bullet racing, suspension - TEIN. didnt know which one you meant since you didnt really ask me?
lol, no... not towin any boats or anythin.
the washer between the plates was worn out or something.
dan replaced it a few wks back.
something went wrong last sunday taking off up a steep hill and started to make a really loud noise.
ended up being the spiggot bush which was replaced today.
also replaced some needle thing in the clutch to from what it orginally came with to a nismo one.
feels alot smoother with the gear changes now.
1200HP CLUTCH!!!
w00t
Guest
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
