Heres my baby
u guys reckon i should put some sort of sticker on there to break it up, im not a big fan on the shoppinglist n all the stuff that looks to out there, or just leave it??
Do you have any pics from behind??? I want mine to have a fat ass like this one day!! :D
His profile says he owns an r32 gtr......
lol never met the block.. just know of him...
Thanks man.. it's a big no no to get impuls now.. because every joe blow has them... but they're very very nice.. probably the most complimented modifcation i've got
And yeah i wasnt gunna get them cause I already know the rims i want, but they do look really nice!!! I prefer non-dish rims personally but those are very nice, one of the cleanest ive seen...
Edited by r32line
Yeah see i new it was prob a GTR, that guy just an ideot - dont worry about him :rofl:
One of those guys that thinks he better than everyone else, yet actually has no clue.
I would love to see a pic of your engine bay also :D and the ass of your wide body car
mate u fink its not a gtr huh would u like pics of my engine bay huh
my bad, i thought these vertex wide bodies were made for the GTST only =) and yeah show some more pics I like the fatness of it
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
