what about 91 gts-t's m specs they came out with the all silver badge, does that mean there still turbo?
yeah man gts-t's are i dont know why they used different coloured badges
oh yeah 500!
ok im not too sure but from what i see a GTS is a non turbo and a GTS-T is turbo, so the T in GTS-T means turbo and with a GTS-T Mspec it still has a turbo but the M spec on the end means a new stlye as in different body styling like new side skirts and front and rear bumpers, soooo the gtr and gts-4 is the same so 4 in gts 4 means 4 wheel drive and the r in gtr means rear wheel drive hahah(just got told the r doesnt mean rwd so yeah shows what i know hehe) not sure bout the last two kinda made them up but it makes some sense correct me if im totally off anyone?
Edited by Caza
oh yeah 500!
ok im not too sure but from what i see a GTS is a non turbo and a GTS-T is turbo, so the T in GTS-T means turbo and with a GTS-T Mspec it still has a turbo but the M spec on the end means a new stlye as in different body styling like new side skirts and front and rear bumpers, soooo the gtr and gts-4 is the same so 4 in gts 4 means 4 wheel drive and the r in gtr means rear wheel hahah not sure bout the last two kinda made them up but it makes some sense correct me if im totally off anyone?
a GT-R is not rear wheel drive......
lol... you're basing that on the colour of the badges? :kiss:
maybe try getting the VIN and posting it in the FAST thread, they'd be able to find out straight away if it is a turbo or not.
also look at things like - does it have 4 or 5 stud wheels, what type of brakes does it have? (M-specs had the big 4-spot fronts) does the dash have a boost guage built into it stock?
because im thnking of buying a a r32 gts-t m spec 91 and i wanna know if its original turbo because i have never seen a all silver badge? im suprised know one here knows anything about it
i dont think it depends on the colour of the badge.... but yeah its turbo but not sure if its original unless you ask the seller i suppose?
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
