what about 91 gts-t's m specs they came out with the all silver badge, does that mean there still turbo?
yeah man gts-t's are i dont know why they used different coloured badges
oh yeah 500!
ok im not too sure but from what i see a GTS is a non turbo and a GTS-T is turbo, so the T in GTS-T means turbo and with a GTS-T Mspec it still has a turbo but the M spec on the end means a new stlye as in different body styling like new side skirts and front and rear bumpers, soooo the gtr and gts-4 is the same so 4 in gts 4 means 4 wheel drive and the r in gtr means rear wheel drive hahah(just got told the r doesnt mean rwd so yeah shows what i know hehe) not sure bout the last two kinda made them up but it makes some sense correct me if im totally off anyone?
Edited by Caza
oh yeah 500!
ok im not too sure but from what i see a GTS is a non turbo and a GTS-T is turbo, so the T in GTS-T means turbo and with a GTS-T Mspec it still has a turbo but the M spec on the end means a new stlye as in different body styling like new side skirts and front and rear bumpers, soooo the gtr and gts-4 is the same so 4 in gts 4 means 4 wheel drive and the r in gtr means rear wheel hahah not sure bout the last two kinda made them up but it makes some sense correct me if im totally off anyone?
a GT-R is not rear wheel drive......
lol... you're basing that on the colour of the badges? :kiss:
maybe try getting the VIN and posting it in the FAST thread, they'd be able to find out straight away if it is a turbo or not.
also look at things like - does it have 4 or 5 stud wheels, what type of brakes does it have? (M-specs had the big 4-spot fronts) does the dash have a boost guage built into it stock?
because im thnking of buying a a r32 gts-t m spec 91 and i wanna know if its original turbo because i have never seen a all silver badge? im suprised know one here knows anything about it
i dont think it depends on the colour of the badge.... but yeah its turbo but not sure if its original unless you ask the seller i suppose?
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
