Thanks for the comments guys
Fronts 17 x 9.5 + 17 with 215/40/R17 tires
Rears 18 x 10 + 18 with 245/40/R18 tires
More pictures to come tomorrow, the car has been sitting for a bit so I'll give it a wash and polish then take some more pictures
I think I have found a set I want to keep...
Haha its not even dirty!
Iv been a member on here for a while now, so i thnk its time i posted a pic of my car. Thier only dodgie phone pics that i took tonight, hopfully in the next week ill get some more pics with a better camera.
[iM
Love the 4 door 32... I reckon they look great, with so much potential!
Guards are all done now. In those pics, the rear guards were just pumped using the newspaper technique. It helped with clearance, but was still rubbing with every bump. Ended up borrowing a roller and gave it a little more of a flare/pump. It's all good now as far as I know, no rubbing at all. Fronts just needed a roll and it's all good as well.
His rear tyres are actually 235s not 245s.
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
