IT took two days but i got through all 199 pages. Some real nice cars in here!
hears one of my two :rolleyes:
your veilside gtr is the same colour as my mates BSM GTR which raced in superlap! im sure he told me it was the blue used on the BA ford - name slips my mind atm
^ so much love for this car..from memory you have meisters?
i'm currently waiting for mine to come from japan :D
Cheers. Yeah, still rolling on Meisters. Was going to sell them to get something different at the start of the year, but decided to stick with them.
You importing a 32 as well?
On topic, some more pics from the downshift meet
U should bring your front lip back to factory...I think they look best in that low sheen grey. And besides that, there will be no paint to chip and crack :)
Front bar was rattle can painted by the person I bought it off.
Waiting to get some spare cash for a respray and then am planning on returning the front lip to that colour. My wife gave birth to twins at the start of last year, so at the moment there are a lot more priorities before the car even enters the picture, and when it does, it's generally just basic maintenance. Aesthetics are a long way down Maslow's hierarchy of needs
Edited by PWND
what are you paying for your meisters? Probably the most suitable rim for the r32!
I completely misread his statement as waiting on his r32 to arrive from Japan. Had I actually looked at this profile, I could have seen he already owns one...
I understand your position as I have a 2 yr old and an 8 week old baby...congrats on your twins, that would be very cute :)
Btw - I too have a small 'to do' which has been sitting on the bench for way too long, due to other priorities hehe
Yeh haha i already got the car, just waiting on rims. i got them on special from the jdm concept business listings sale. still an expensive rim but at the end of the day i couldn't pass up on the price compared to what they normally are :P nor could i allow myself to roll around on rota's or some shit :P (no offence to rota owners)
and yeah they really are the best rim for 32's
will be followed by pics in the weeks to come.
That's my old car (kandy red one).
Body has always been GTR spec (front and rear guards, bumper, skirts etc etc.).
Went back to bare metal for a fresh ground up build.
A deposit has been taken on the completed project so it's not mine anymore :(
But I recently bought a white R32 GTR which I'm building for myself. ;)
what is the process in smoothing down an engine bay?
basically rubbing it all back, then welding plates in instead of using bog. my radiator support also doesn't have any holes now. going to hate putting the motor back in along with everything. going to cry if i scratch it
