Any idea of the brand?
Tried sending a pm to femno but inbox is full
They're a nice looking skirt aren't they. I'm not sure what brand they are but I have TRUST GRACER skirts on my 32 GTR and they're a similar style but a hell of a lot more pumped out than femnos. I didnt like them at all when I first bought the car with the original rims but with big wheels I think they look great. Unfortunately I haven't got any decent pics with the new wheels on though as the car hasn't been in a photo worthy state for 3 years lol.
