Haltech, oem BOV's, a re-tune, driver/passenger windows and a engine bay detail this weekend ? OK
sounds good. Ill drop it off on saturday and pick up sunday?
Also prob am detailing this weekend
Yeah mate for sure, when I get back from the states later this year we should get them all together
Definitely! Always good to meet fellow 32 GTR owners.
The gtr in front is mine and behind is my brothers which is a Scuderia gtr. 1 of 6 and his is compliance number 001. Has standard n1 front and rear lip with snorkels, scuderia boot badge, scuderia instrument cluster and scuderia compliance plate as the car came to aust as a low volume import and sold here back in 89, via scuderia showroom in Vic. This is an old pic taken in 2004.
That is so cool that both you and your brother own Silver R32 GTR's!
Tiits and Ass, Titts and Ass
What are you up to Matty T ? A quiet SOB most of the time lately :P
Lurking mate, just lurking, i am a quiet SOB of late :P
Awaiting Container "A" to arrive, so i can have my goodies from our friends in Japan. That and i should see if my manifold has been started too, then i can get into swinging spanners and taking the TD06 kit off......but as im going to be moving soon, i would prefer to keep the car in a driveable state (well, drive on drive off the trailer anyways :laugh:)
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
