What i dont get in the first post, is you where saying after putting the rb 25 into you car the tailshaft seemed to long? say 3cm, that means the engine/gearbox would be sitting back 3cm, so the gearbox mounts wouldnt line up? and then you said about the gearstick sitting forward? or somethuing, im really confuised, from the other posts ive read the gearbox should stay the same?
im so glad im using my wiring guy to do the loom, does it over night :rofl: perfect 100% of the time
JV
its because he went from auto to manual. box length isn't the same and neither are the mounts
ok so should it stay the same length manual to manual?
like ive got a rb20 witha 25box, made the custom mounts already, will the length stay the same for the tailshaft??
cheers JV
no... the gearbox is longer and the bolts dont line up! (custom xmember) also modify tailshaft (shorter) is required!
what do you mean, do you mean a r33 box needs custom mounts to mount in a r32? if so i have already done that,
I have a rb20 with a rb25 gearbox, i have modified the gearbox mount as it sits further back so the holes line up, and i have a 1piece customs tailshaft,
So When i stick the rb25 engine in, will the gearbox still mount up with my custom mounts? or am i going to have to modify them again>?
hope this made it clearer,
JV
i never had any problems with the gear box mount nor the tail shaft.
neither need modifying except for the yoke on the end to fit the output on the box...no length change was needed.
how??
the rb25 and 25 box are bothe bigger hence the gearbox being longer than the standard rb20 xmember mounting points!
so saying that with the 25box and engine the mount sits 2cm ish further back. then u need to mod the yoke and shorten the tailshaft!
Adrian,
Stress less about the tail shaft. All that is required is to cut the old RB20det yoke off the R32 rb20det tail shaft and weld the rb25det yoke on to it.
Thge rb25det box sits something like 10mm back than the rb20det box. When you remove and clean up the old weld etc from the rb20det yoke thats the 10mm or so required. So stress less drop it off at the local Adelaide tail shaft services and simply have them swap the yokes + balance for $90.
Quiz Shaun he will tell you the same. I've done it to mine and thats how it is with the factory 5speed R32 GTST's. :down: The Ceffy's and auto R32 GTST's have slightly different mounting positions.
So Oblivion your R32 is an Auto from factory. :ninja:
I have a question about the swap. I got my rb25 but one og the mounts is broken. Someone told me I can take the motor brackets of the rb20 and put it on the rb25 and still be able to use my old mounts. Is this true?
  • 3 weeks later...
ok so ive almost done my rb25 conversion,
things i might mention,
My rb20 accel cable works fine on this engine, have a bit of room for adjustment, so it can be tightened if i wanna tighten it a bit, (maybe because i got my engine from a stagea? different throttle body?)
If you want to use the non hicas pump, use the rb25 balancer, i found my rb20 balancer ps belt was 4 ribs and the rb25 1 is 3 ribs for ps, the rb25 ps bracket u cant fit the rb20 one onto either,
if you get a awd motor, you will have to mod the sump, i bashed mine with a hammer, most bolts fit in except about 3, so it should be fine, (fingers crossed),
also, if using a awd motor, the 4 bolts from the gearbox to engine (on the bottom) theres nothing to bolt them into on the side of the engine, i just bolted them up anyways and had it rest on the side of the engine,
anything else i will add later,
JV
  • 3 weeks later...
  • 1 month later...
been mentioned several times in various threads about the wipers when doin the conversion. easiest way is to un splice the rb20 loom and take the smaller sub loom to the wiper motor and add it to your rb25 loom.
  • 2 months later...
I'm done labeling the RB25 dash plug (big one next to the ECU) and almost done with the RB20 plugs. I also started a little guide to show which wires connect to each other f.e. :
12 pin plug (R32) = PIN 1 R32 Black/Pink TO R33 Black/Pink. I'm still missing 7 wires.
What I've got now is :
16 pin plug
R32 R33
Pin 1 : Black Black
Pin 2 : Yellow/green Brown/yellow
Pin 3 : Yellow Yellow
Pin 4 : Yellow/red Yellow/red
Pin 5 : ??? ???
Pin 6 : ------ ------
Pin 7 : ------ ------
Pin 8 : Black/yellow ???
Pin 9 : Light green.red Pink + Black
Pin 10: -------- -------
Pin 11: Yellow/purple Yellow/purple
Pin 12 to Pin 16 are empty
12 Pin plug
Pin 1 : Black/pink Black/pink
Pin 2 : Yellow/green Yellow/green
Pin 3 : Orange Red/white
Pin 4 : Black/yellow Grey.red
Pin 5 : Brown ????
Pin 6 : Light green ????
Pin 7 : ???? ????
Pin 8 : Yellow/red Yellow/blue
Pin 9 : --------- -------
Pin 10: Light green/black ????
Pin 11: Light green/ red ????
Pin 12: Black Black
And the last 12 Pin plug (big one) that has 2 wires I don't know them
might make it a little easyer if you know what the wires are not just the colours ect to write that next to it aswell...
i cant really be bothered my dash and vct still dont work but it runs still so im happy lol..
I also know what they are...thats how I made this guide :
16 pin plug
R32 R33
Pin 1 : Black Black
Pin 5 : ??? ???
12 Pin plug
Pin 5 : Brown ????
Pin 7 : ???? ????
Pin 12: Black Black
  • 3 weeks later...
Here is my wiring - I think there are some errors, but it should help. I will revise if there are any errors.
r32_rb25_wiring01.doc
This is for series1 rb25 engine, don't know anything about series2.
Please don't ask me mountains of questions, I probably don't know, it's been years and years since the conversion.
Diagram 1 shows the location near the airbox side. The 2nd plug near there I think can be left spare.
Diagram 3. Up near the wiper area there is another plug which is pretty much spare. Run another wire from the orange to the footwell area.
Diagram 3b is where to run this extra wiring to the footwell plug. Off this run the thick black and the thick white to the fuel pump resistor
Diagram 4 shows near the passenger footwell on the r32 body loom, which is the fattest plug. As far as I remember this is "spare".
Diagram 5 is the main two plugs which need most of the wiring from the old rb25 body loom plug cut and wired to these.
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
