  • Replies 47
Well anyway back on topic...
Who does the tuning at BD4s, is it Tom or the other guy?
I just found out from my HK buddies that to get the HKS gear tuned it costs them almost $5,000AUD
They get some guy from Jun in Japan to fly over and do the tuning... imagine if that was the same here :(
Jim at CRD tuned my car, I found that the car had more torque off boost and less black soot build up on my rear bar compared to the previous road tune.
The car started pinging after about a 2 weeks (bad fuel?) and Jim spent about half an hour retuning it - at no cost – and it hasn’t pinged since.
I haven’t been to BD4’s
Pity your car wasnt ready to tune a few weeks ago Stan.
Just Jap had the owner of Autech Japan out here and he is an F-CON tuning guru.
...The car started pinging after about a 2 weeks (bad fuel?) and Jim spent about half an hour retuning it - at no cost – and it hasn’t pinged since....
now here's the question.
Was it bad fuel or a bad tune in the first place?
If it was just one batch of bad fuel, couldn't you put it back to the earlier/ better tune once you put new fuel in? Or was it tuned without sufficent margin for safety on the road, taking into account variable fuel, hot days etc.
Did you get a dyno graph from the first tune? what were the AFRs? How much base timing?
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
