broker
Guest andrewjread
heres the story. My skyline is getting the compliance plate early next week. After speaking to a broker about 8 weeks ago who said that he had found me insurance for this particular vehicle, I started the search for this car I have longed for. He said call back when it is ready for licensing and Ill send out the papers. Now that my car is almost ready, I have contacted him and hes said that he cant get insurance for skylines anymore.
Im 24yo turning 25 in May and its a 1993 gts25t.
What insurance company should I go to? I will get the best alarm and I have an advanced driving certificate.
Yes there are threads with same subject but I NEED fresh information.
I cant @#$% believe this has happened when its getting so close to having my car after waiting 8 bloody weeks.
https://www.sau.com.au/forums/topic/12017-broker/
K - here's the contact details:
IPS Insurance Brokers
Ph - 9440 4055
These guys were the only ones interested in insuring my line. I'm 26, had only just got my license back before buying the car, but had a 60% NCB with my last insurer. The premium charge was about $800. A shiteload cheaper than the 2.5k that some of the bigger companies wanted..
Good luck..
https://www.sau.com.au/forums/topic/12017-broker/#findComment-213942
Andrew,
I had some troubles with Cam's broker too, but found this guy to be marginally more helpful. the price he quoted me was also pretty competetive.
Fletcher Insurance Brokers
John Fletcher
9525-5497
[email protected]
Im in the same situation as you though. John's supposed to be getting back to me to confirm.
Is your car in Aus yet? or are you one of the people waiting for the Divvy.
Stupid slow boat.
https://www.sau.com.au/forums/topic/12017-broker/#findComment-214327
Originally posted by PSIKO
You guys got pics of your new rides?
see avatar.
other pics available, but nothing much more than the gold rims to rave about.
For first prize in the import broker poetic licence stakes, can anyone tell me the name of the company that makes the "aftermarket" factory option bodykit?
https://www.sau.com.au/forums/topic/12017-broker/#findComment-214796
I meant - quarentined and cleaned - not just quarantined. If the car is too dirty - with things that customs think could cause probs in Oz - like soil etc. Then is has to be cleaned by them. My car just had dust - so I drove it from the wharf with her looking filthy as a pig. hahaha
https://www.sau.com.au/forums/topic/12017-broker/#findComment-216531
Andrew
Give Tammy Fazio a call at Silvalake (they're an insurance broker) - I've insured my last and current GT-R with them at a half way decent price:
SILVALAKE FINANCIAL SERVICES GROUP
Ste 7/1297 Hay St
Perth WA 6000
(just next to Miss Mauds upstairs)
Tel: (08) 9481 3855
Fax: (08) 9481 3866
Cheers
Brendan
https://www.sau.com.au/forums/topic/12017-broker/#findComment-216719
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
