broker
Guest andrewjread
heres the story. My skyline is getting the compliance plate early next week. After speaking to a broker about 8 weeks ago who said that he had found me insurance for this particular vehicle, I started the search for this car I have longed for. He said call back when it is ready for licensing and Ill send out the papers. Now that my car is almost ready, I have contacted him and hes said that he cant get insurance for skylines anymore.
Im 24yo turning 25 in May and its a 1993 gts25t.
What insurance company should I go to? I will get the best alarm and I have an advanced driving certificate.
Yes there are threads with same subject but I NEED fresh information.
I cant @#$% believe this has happened when its getting so close to having my car after waiting 8 bloody weeks.
https://www.sau.com.au/forums/topic/12017-broker/
K - here's the contact details:
IPS Insurance Brokers
Ph - 9440 4055
These guys were the only ones interested in insuring my line. I'm 26, had only just got my license back before buying the car, but had a 60% NCB with my last insurer. The premium charge was about $800. A shiteload cheaper than the 2.5k that some of the bigger companies wanted..
Good luck..
https://www.sau.com.au/forums/topic/12017-broker/#findComment-213942
Andrew,
I had some troubles with Cam's broker too, but found this guy to be marginally more helpful. the price he quoted me was also pretty competetive.
Fletcher Insurance Brokers
John Fletcher
9525-5497
[email protected]
Im in the same situation as you though. John's supposed to be getting back to me to confirm.
Is your car in Aus yet? or are you one of the people waiting for the Divvy.
Stupid slow boat.
https://www.sau.com.au/forums/topic/12017-broker/#findComment-214327
Originally posted by PSIKO
You guys got pics of your new rides?
see avatar.
other pics available, but nothing much more than the gold rims to rave about.
For first prize in the import broker poetic licence stakes, can anyone tell me the name of the company that makes the "aftermarket" factory option bodykit?
https://www.sau.com.au/forums/topic/12017-broker/#findComment-214796
I meant - quarentined and cleaned - not just quarantined. If the car is too dirty - with things that customs think could cause probs in Oz - like soil etc. Then is has to be cleaned by them. My car just had dust - so I drove it from the wharf with her looking filthy as a pig. hahaha
https://www.sau.com.au/forums/topic/12017-broker/#findComment-216531
Andrew
Give Tammy Fazio a call at Silvalake (they're an insurance broker) - I've insured my last and current GT-R with them at a half way decent price:
SILVALAKE FINANCIAL SERVICES GROUP
Ste 7/1297 Hay St
Perth WA 6000
(just next to Miss Mauds upstairs)
Tel: (08) 9481 3855
Fax: (08) 9481 3866
Cheers
Brendan
https://www.sau.com.au/forums/topic/12017-broker/#findComment-216719
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
