whats a crows foot tool and what do they look like? lol
okay i just got 290km out of a full tank on my car :D , just over half a tank was used on the xmas cruise
and thats with the fuel light beeing on for about 6km :P
i think i might change my o2 sensor soon :P see if that makes a difference
https://www.sau.com.au/forums/topic/120328-fuel/page/11/#findComment-2773837
  • Replies 242
sounds like a plan dude, 290 is shithouse
https://www.sau.com.au/forums/topic/120328-fuel/page/11/#findComment-2773838
yeh, my fuel consumption is getting worse and worse and i dont know why :D
also with these NGK o2 sensors are they direct replacement that includes the clip or do you have to cut the existing wires? :P
rekon it might have something to do with your missfiring aswell ?
https://www.sau.com.au/forums/topic/120328-fuel/page/11/#findComment-2773950
i was getting about 280km out of a tank and decided to change the o2 sensor to the NGK which everyone is saying to do and have done and gotten results with. Had to fill up today after only doing 295km with a lot of cruising :D . Im out of ideas and cant really afford this so anyone else know what i can do...ill try anything?
Edited by Onthehunt
https://www.sau.com.au/forums/topic/120328-fuel/page/11/#findComment-2774023
Just an update. I've been averaging around 300 - 320 km from full to fuel-light. I've run some injector cleaner through it and now I'm getting 350 - 380 km. I got the 380 after the cruise and a lot of freeway driving though so I guess that's to be expected.
Hopefully early 2007 I'll be able to afford to let her breathe a bit easier, so we'll see what happens then.
https://www.sau.com.au/forums/topic/120328-fuel/page/11/#findComment-2778659
Just come back from the usual christmas break down south and got 11.5l per 100K in the GTR (460km from about 53L). Mostly 80 - 110kph country driving but it also included the odd full fang up to the speed limit and overtaking.
Best figures yet.
https://www.sau.com.au/forums/topic/120328-fuel/page/11/#findComment-2778693
i was getting about 280km out of a tank and decided to change the o2 sensor to the NGK which everyone is saying to do and have done and gotten results with. Had to fill up today after only doing 295km with a lot of cruising :/ . Im out of ideas and cant really afford this so anyone else know what i can do...ill try anything?
Didnt work???? Thats a big surprise. How spirited is your cruising? Maybe swap air flow metres with someone for a week to see if that changes anything. If it does, go buy a newer one?
https://www.sau.com.au/forums/topic/120328-fuel/page/11/#findComment-2779302
hey brad,
yeh im really surprised myself. was alot of cruising. really didnt put foot down in that tank(which was hard to do :D). Tried injector cleaner as well and that didn't do anything either.
Resetted the ecu today so have to see if that does anything. car seems to run better so far since resetting . I had a look to see if there was a piggyback that might have changed the fuel mixture to make it run really rich but nothing so dont think thats been changed. Getting desperate...cant afford to keep going like this ;)
anyone got a spare air flow metre i can borrow? or any ideas?
https://www.sau.com.au/forums/topic/120328-fuel/page/11/#findComment-2779634
Navin,
Been thinking about it and it doesnt seem right. Maybe the new sensor is faulty from factory? Bring your car back to me next week some time and ill put a new one in it and see if it changes anything. May not work but its worth a try. I am just very surprised it did not work as i have done it on several cars and it has had a 100% fix. Let me know if you want to try this. (straight swap, no charge of course)
https://www.sau.com.au/forums/topic/120328-fuel/page/11/#findComment-2782720
  • 2 months later...
ive had my car for about 3 weeks and it seems ive been spending a hell of a lot of money on petrol.
i had 60$ in it on the weekend and it went up to 3/4's of a tank and ive only gotten about 150 Kms out of it.
i had to put crappy vortex in just 20$ last night because i was scared i was going to run out of petrol, and so when thats down im going to BP with my 4c off voucher and filling up on ultimate!
ill see how many kms i get and how many litres i put in.. and then i might do that wynns injector cleaner to see if that helps me.
ill post up what happens when i do it.
https://www.sau.com.au/forums/topic/120328-fuel/page/11/#findComment-3015009
pity its only 95 octane
ihave heard shell and caltex have made an arrangement with bp ( the only fuel supplier in W.A.) to carry 98 octane
so it looks like no matter where we buy our 98 octane it will be bp ultimate just re labeled either shell or caltex
Hi, guys. Came into this all rather late. There are a number of threads discussing fuel supplies in WA and elsewhere in Australia, which refineries supply where and so on. For example, see Optimax Fuel Quality. Unless it has changed in the last twelve months, BP Ultimate is the only 98 octane fuel available in WA.
There are also many threads on fuel consumption, so the "search" button is your friend! My understanding is that the factory ECU is programmed to run fairly rich. As you modify the car, by fitting less restrictive intake and zorst, it will run richer still, so your fuel consumption will go up - and so will the amount of black crap on the back of the car. Re-tuning, via a piggyback system (e.g. SAFC) or a replacement ECU (e.g. Power FC) allows you to lean out the mixture. But the factory ECU is deliberately tuned rich to minimise the potential for detonation. So if you lean out the mixture, you are increasing the chances of detonation. Hence your tuner needs to optimise your mixture to leave sufficient margin to avoid detonation, thus giving better power and happily gaining improved fuel consumption.
Replacing the O2 sensor may help, but I suspect that this would not be a long-lasting fix, as it was probably covered in black crap. Without fixing the fundamental issue of running rich, it wil just get covered in black crap again. Obviously the performance of the O2 sensor will affect the richness of the mixture and the amount of black crap produced, so it is not a linear relationship, but it is not a once and for all fix.
Incidentally, I get typically 360km per tank in my R33 GTST, filling up before the fuel light comes on (around 50 litres). On a long run down South, I will get 450 to 500 km. Fuel consumption improved when I fitted an R34 GTT intercooler.
Hope this helps.
Cheers. :happy:
https://www.sau.com.au/forums/topic/120328-fuel/page/11/#findComment-3015850
hey guys,
i usually get about 400km's from 50 litres and thats a combination of freeway travelling and loads of city driving. i would suggest bring ur car for dyno and check out the air fuel ratio. If the air fuel ratio is way too high then get a new afm or a SAFC so that the air fuel ratio will run at optimum and if its running optimum u will get the best out of ur car power and fuel economy wise. Usually if ur car is running way too rich and consuming too much petrol you would be able to see it on the dyno sheet for air fuel ratio....
Hope this helps
Bernard aka SLOWPOK3
https://www.sau.com.au/forums/topic/120328-fuel/page/11/#findComment-3015982
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
