HOWTO: Disable R33 Door Unlock Button
Intended Audience: Anyone concerned about their car safety
Technical Level: Low
Duration: 15 minutes
Effort: Low
Result: Very High
!!!Caution/Achtung/Attenzione!!!
Follow this guide at your own risk. You have been warned. We are not responsible for any actions you take. The information contained herein is a guide and should *not* be acted upon with consultation from your local tuner (he/she may not agree with my comments / suggestions). If you are unsure or are not confident don't do it.
This guide shows you how to disable the door unlock button on the R33 Skyline. It is a common known security flaw that this button works when the car is locked/alarm is on. Thieves can bend back your window and then press this button to unlock the passenger door. Once this has been done they are free to enter your car and do as they please. The factory alarm doesn't seem to be triggered by this break in method.
Tools you will need;
Phillipshead Screwdriver
Electrical Tape
Scissors or Pliers
1. Open driver side door. Remove the screw cover inside the door handle area and undo the phillips head screw. Carefully lift up the Power Window / Door Button harness cradle from the door.
2. Locate the wiring loom attached to the end of the controller unit and cut the Brown wire. Once this wire has been cut tape up both ends with Electrical tape.
3. Put keys into your ignition and turn to ACC. Test to see if the door unlock button works. It shouldn't
4. Tape up the remaining part of the loom and place the cradle back into the door. Screw it back into place and place the screw cover back on.
  • 1 month later...
Sounds like a good idea, but you loose the door unlock function to go with it I take it? I do actually find this very handy as my alarm auto locks the doors when driving & I let passengers in & out with it a lot.
If you had a relay linked to the ignition power it would still allow this function to be used while securing your car when it is locked/alarmed too.
  • Like 1
  • 3 weeks later...
youll have to pull out your door lock button and have a look.
i dont see why they would have changed it for the gtt.
the wiring should be common on all the skylines, at least you would expect
best idea. there is an IGN feed already there to do it.
  • 3 weeks later...
just finished doin this on my dad's ceffy (which also has the same button in a similar position). Made sure the switch only worked when the alarm was disabled by using an alternate earth signal (which I got from the ignition switch).
  • 6 months later...
I have a '97 skyline r33 Series II. I tried pressing the passenger window button when i locked the car with the alarm on and the window didnt come down. I also tried it on the drivers side button while doors were closed and the window didnt come down. This exploit must of been fixed in the '97 skylines?
nope your talking about a completely different button... its not the power window switches..
its the passenger door unlock button.. Just below the passenger window button
  • 8 months later...
whats/wheres the ignition switch ?
i wana do this, but make it so it still works when the cars turned on.
You need to buy a relay and switch it via the IGN wire on the connector.
If you need help i could do it for you, you just need to go to Jaycar, or wherever, and buy the relay.
oh ya i found the ign wire just now with the multimeter. think its the big yellow one.
couldnt i just chop the brown wire and connect it the yellow/ign ??
with the relay there will be 3 points ya ?? what would i connect them upto
thanks :thumbsup:
Have looked for the last 1/2hr for the farken life of me i can't find a simple farken wiring diagram for a common farken relay. Therefore i can't tell ya what to hook up to where.
THE WEB IS FULL OF USELESS SHIT!!!
You need one pin to hook to ACC
the 2nd to hook to GND
The 3rd to one half of the brown wire
The 4th to the other half of the brown wire.
I think it's:
Pin 86 => Acc
Pin 85 => GND
Pin 87 => 1st half of Brown wire
Pin 30 => 2nd half of Brown wire
Your common 10amp relay is more than enough.
ya i was looking on google 2.. 'howto use a relay' etc etc. then i got tired of looking and pm'd you :thumbsup:
3 --/ -- 5
1 --88-- 2
is on the relay i got
That should be it!
Pin 1 = ACC
Pin 2 = GND
Pin 3 = 1st half of Brown wire
Pin 5 = 2nd half of Brown wire
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
