  • Replies 136
You can get slot DVDRW drive that dont have a tray, much like most head units. ie cd slide in by a motorized roller. Dont know much power they eat up though, but that's what I'm gonna be doing. Then you can get the best of every world, cd, cdrw, dvd, dvdrw.
Hmm good point, i've never seen them before, then i'm not really much of a tech head, i'm very interested but pritty much know bugger all ;) I know what your mean though, like a normall car CD player, keep us posted how you go.
Michael
most laptop cd/dvd drives are cd-cdr-cdrw-dvd-dvdrw-blah blah these days. If you can get your hands on a slimline drive go for it.
It would be really cool in the dash under the screen if you have a setup like Parish's in my opinion.
Booya:
http://www.auspcmarket.com.au/show_product...5D=MU-PIDVRK06L
Am sure you can find one for cheaper, but that's pretty much the best thing to get if your looking for all in one DVD Drive
Edited by Liiger
Hey has anyone got that USB boot thing working yet?
I've read through some of the website but haven't been successfull in getting my USB key to boot the OS. It boots off the key but stops cause it can't find some system file that is part of windows.
Yeah I read through that same guide, got it to boot but said there was a particular file missing, one need to boot up windows or something.
Pretty much stepped through it exactly but something still ain't right. Oh well I'll keep trying!
hey just found this thread, what a fantastic idea with the car-pc!
i might add a couple of improvements tho, firstly you could get a USB 802.11b/g wireless card... you can get external antenae for them also to improve reception, hence eliminating the need to transfer files/data via a cd drive or usb key. Obviously secure it or disable it when you dont use it!
next for those who are having issues booting off usb, you can buy things called Disc On Modules which are in effect, flash memory built into a 40-pin IDE connector.
So you plug it into the HD connector and it should detect as a HD... havnt seen prices for anything larger than 128mb, but they say theyre available up to 1.5gb. Keep an eye out for them, they may be the next cool thing.
As for speed with flash memory well there are pros/cons, most memory has extremely low latency (fast seek time) but transfer speeds are low compared to HD's. Also they have no moving parts. So would be great for opening/moving small files, but churn with large file copies etc.
I've also heard of some ppl using mini-ITX boards with Compact Flash adapters onboard. Lots of modems/routers use this method for booting skeleton versions of Linux, but I cant see why Windows couldnt work. Compact Flash cards can be bought in sizes up to 3-4gb im fairly sure.
Anyway nice work to those who have made them, got me motivated for when i look at stereos in my car :thumbsup:
  • 10 months later...
What do you call fast booting?
Restore from hibernation is quick enough for my carputer.
ditto. Keep the RAM size small (256MB for me) and return from hibernate is plenty quick enough.
If you had a dual battery setup with isolation circuit, you could even keep the pc in suspend-to-ram mode for instant turn on. A deep cycle gel-cell as the 2nd battery should keep suspend mode going for a few days.
with mine keep a 1000cca battery with a isolator off the main battery. I can run it into the ground and the vehicle still goes. when I'm on site I plug the van in and it switches straight to mains and shuts the inverter down. remove power and it fires right up without a glitch.
hardware wise: 7 port usb hub HP 1200 laserjet printer,40gb hd, 4g RAM, 3g modem, keyboard and mouse. 3kw inverter
display wise 17" LG monitor. base machine is a acer laptop. OS is winXP - extra memory is for quicken - its a memory hog!
it will run 3 days before shutting down. I use it daily for invoicing and general internet when I need info quickly.. it is also networked back to the workshop SBS server (quickbooks sits on this.)
the whole lot in integrated in the floor of my van . (if someone knows how to empty a nokia N70 memory card without the lead I'll show you the pictures.)
I didnt really consider a second battery thinking that the time it would last wouldnt be that great but a few days you say? awesome, whats involved in putting in a second battery and an isolation circuit?
you can buy them:
http://www.4wdsystems.com.au/html/isolators.htm
or make them (search for isolation circuit, or tank circuit):
http://mp3car.com
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
