for the wheels... well im looking at the model 5 copies on uniqueautosport website that are $1180 then buying second hand tyres. so they would have to work out less than that cause i prefer the model 5 to vs-5 (or whatever your model is called) even if they are copies.
thats what i was planning to do, by a standard bar and hack into it to fit the fmic. more stealth than the big trust bar.
040 goes in factory location - in tank,
If you are serious about wanting parts, then PM me your offers, but parts wont go cheaply as my preference is to sell the car complete, unless i find a buyer to buy my car less bits.
Thats not to say ill be asking for new part prices, but say i wont accept $500 for rims, of $600 etc for intercooler.
It is a Type S intercooler, from memory 600 x 300 x 60mm (or 76 check their website)
It came with HKS piping and hose/clamps, to look at the material is powder coated mild steel.
As for condition as i run mesh on my front bar it is in great condition, after a quick dip in some caustic to clean it up it would look like new, ie not a bent fin on the cooler, not one!
I dont have an oil/air separator so MAY have a thin film of oil on the inside that will clean up easy with the caustic bath.
Will try to take some more pics over the weekend, including interior, engine bay, suspension etc.
So just to clarify for those people who have sent me PM for parts, there is a couple of people kinda interested in the car with filter, zorst, brakes/susp.
If they take it off my hands then i will then be selling the IC, AVC-R, Power FC, oil cooler, Bosch Fuel pump etc AFTER the car is sold.
As i have explained to people i dont want to sell off good bits and be left with stocka that i have to drive every day, or no one wants, so have to sell cheaply like Chef _32's friend.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
