Yep it must be my turn to have my baby violated... on the weekend i was out doing a Harbour cruise and when we came back my driver side window had been forced open and some junkie went through the glove box, which only ever has papers in it and my centre console from which this lesser being took my....... wait for it........ aftershave. He/She also tried to mess withy the ignition but must have realized that there was three cameras pointed at him/ her. I had cds... not touched... my stereo... intact... my door.. bent out of shape but i managed to push the window back so it's not so bad.
I hope this human weed has a bad reaction to CK. :D
https://www.sau.com.au/forums/topic/122144-broken-into/
just keep a look out for anyone smelling pritty swarve in the next week or so, and you may have your self a winner.
out of all things, the after shave? weird people..
i know how you feel though in some ways, i had someone try and force my drivers side window open as well.. just the thought that some low life tryed to break into my car mad my blood boil
https://www.sau.com.au/forums/topic/122144-broken-into/#findComment-2253608
Sorry to hear MAR55S, I know exactly how you feel... at least they didn't smash your windows and screw all the trims up :yes:
After shave ehh? Almost as good as taking my head deck case full of banjo bolts :D
Hope you get everything sorted out soon!
https://www.sau.com.au/forums/topic/122144-broken-into/#findComment-2253757
AFAIK, MAR55S ALWAYS parks his car in a secure car park with camera's and so forth on a Saturday night. (I know which one it is but will not disclose it in public)
Hence saying "parking the car in the city, in the dark, all alone... come on mars, ofcourse you should expect something like this happening =(" is a bit rough and maybe you should consider editing your post before you unnecessarily upset a fellow forum member.
No one should ever have to EXPECT to have their car broken into.
https://www.sau.com.au/forums/topic/122144-broken-into/#findComment-2254632
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
