Pitty the place is a shit hole. no water, no power, toilets 2km away, no showers, poor PA system. if it wasnt for good company last time i would never consider camping there again.
For sure!! The people at WB are awesome and nothing is too much trouble.
  • Replies 218
No water- yeah its called a drought
Id put up with all the things you listed at WB anyday over the sht way WSID is run.
WSID is the only track we refused to tow to when I had my dragster and I will never ever go there to race or spectate-would rather burn my money than spend it there.
As for more peolpe getting involved from these forums and else where-well thats not going to happen with the current state of play with import drag racing at the moment-I think the scene will struggle to hold onto some current long term members, let alone attrached new ones :(
Edited by gtr660hp
I cant wait for Jambo and if SRWD doesnt have any AWD or 4WD then I have a better chance of being top qualifier.... :/
Adrian,
your not going to make the trip up just because you wont get any points towards your championship?
When we were there in September last year there was a shit load of water!!! Almost 2 inches through the whole venue!!
Adrian
Thats an understatement to say the least....i reckon there was at least 6 inches in the corner of my tent.....water that is...lol
the rule book is out mother fuggers
AWD have there own class, looks like a tussle between the big heav cressida and the light weight 13b mx5 for top qualfier, unless calros comes out int he millenium supra, then we have no chance, 10.04 at 150 mph last year witha 2.3 sixty foot. theres a high 8 in that car
hahahaha you make it sound like your at a disadvantage..... I probably wont get a chance to practice before the event as my axles are 3 weeks away :ninja:
10.04 @ 150mph is pretty impressive.... I dont think my car has a chance going that mph.
Whats the link for the rule book.... I was at the site but it didnt appear to be downloadable...
No trans brake is ok, I havent got mine sorted out yet anyway.
Running alcohol wont affect me either. I might see if I can afford to buy some C16 for the event and up the boost.
Any other exciting changes?
Adrian,
are you going to enter this series?
no aftermarket transmissions
so no powerglides, c4's no supra gearbox behind rotary etc.
if it wasnt an option from the manufacturer its not allowed.
thats interesting and will certainly limit the class.
unless carlos shows up with his manul box in, he wont bein our class.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
