Hey guys,
The other day I made a cold air induction pipe for my 33 GTST. The actual pipe I bought cost $15 from magnet mart and some cable ties which are like 2cents each.
Here are some pics of the final result..
Works a treat!
atchmnt1
atchmnt2
atchmnt3
-JD
Edited by JD-33
https://www.sau.com.au/forums/topic/122374-15-cold-air-intake/
Awesome man its look good!! cheap as well which is a bonus!!
So im guessin u got a fmic, and dont use stock piping??
Got any tips for ppl who still use stock piping??
i got snorkle anyways, but would love to put more cold air for my pod.. (using mr_crusts heatsheild box for stock snorkle)
yeah man, got a FMIC which frees up a hole below the POD..
will take some pics of the inside when i get a chance.. i forgot :D ..
yeah me and my mate are designing some CID pipe for his car which uses stock IC ..
will let you know how it goes..
Cheers,
-JD
nice one...I have done exactly the same but with the Al pipe. Next seal the pod in a box...if u already havn't done so. As for water issues...had this type of setup for ages on all my cars....never had a problem...some have a BNC filter and others the Unifilter...
the filtering properties of a Unifilter for example has dust retention properties of 4microns (paper is 30 and cotton gause is 45!) however with a large enough service area it has been proven to get roughly 25% less restriction than paper filters...and about restriction as a std K&N cotton gause type.
anyway the conbination of the oil soaked foam and the fact water is much greater size than 4micons means ur pretty safe I reckon...(although I don't know what the actual size of water is but its much greater than air/dust!)
Edited by khunjeng
I've ran a 100mm dia cai which is larger than the one in the pic here.
In 4years maybe slightly more and 150,000km's.. Never had a problem.
People worry too much. :domokun:
I've been though those big aquaplaning puddles that you can't see when driving in really heavy rain.
I checked the filter soon after, it was dry the cai did have a little mist in it.
just for the idiots out there, when you drive through a puddle, unless it is about 6 inches or more deeper, the front bar doesn't touch it. it is you wheels that splash it. the front wheels are behind the front bar, so there is no water splashing into the cai.
I just re-used the elbows and piping from my stock intercooler setup (through the hole that was left after the install). Sits inside the front bar perfectly and didn't cost me anything other than 15minutes of thought and half an hour of installation.
I agree with the "no water" thing, and if you are really unsure, just tilt the CAI so it's always pointed downwards, even if water gets in, it'll just run out again.
for water drainage i have pierced small holes in the underneath and backing of it... (used a pin todo so)
its very secure, ive taken it to 175 and she doesnt move at all, this is because the piping is like a slinkee, and i made it longer than as you see it, so when is in there with the cable ties its applying pressure towards to front of the car and ud towards to cabin..
the pipe has no brand, i just asked for an aluminum pipe which is flexible..
cheers,
-JD
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
