Hi all,
I took Wednesday off from work to take care of the other half.... my skyline. I took my car to an exhaust shop to fit my Batmbl split dump/front pipe and catco high flow cat at 8am. As my time with Matt started at 1pm and I live on the northside, I needed it back by 11am. No probs said the exhaust place, at 11:30 I finally get a call and pick her up. Guess what, they put one of their stickers on my back window!!! God I hate that.
After a nice drive down the Pacific highway I get there slightly late. Matt has a small but very good shop, one of his mates was there helping him out with a monster 32 GTR. It had some problems and needed to be pulled apart and Matt doesn't do major mechanical work.
Matt spent about 2 and 1/2 hours tuning and made some major gains over the previous tune at another shop, obviously it had a lot to do with the new exhaust parts. It missed once on the dyno and on the road test drive. So he pulled out the spark plugs and regapped them and it was all sweet. Matt only charged me for two hours on the dyno, he's a cool guy, easy to get along with but wont bullshit you.
As you can see from the dyno chart the power flattens at 5000, thats because the AFM is maxing out. I have a FMIC, EBC, PowerFC, standard turbo at 13.5 psi with Apex power intake and the exhaust I mentioned before with a 3.5 inch catback. I'm pretty happy with the way its going, just need a new Z32 AFM. After I get one I'll try installing it myself or put out the call to northside SAU members to give me a hand if needed :O .170rwkw at 5000 isnt too bad and after a drive up Mt. Mee(unfortunate name) I'm very impressed with the midrange torque and power.
Edited by Nate79
https://www.sau.com.au/forums/topic/122692-my-day-of-tuning-with-matt/
Well as you know I installed my Z32 first thing in the morning before going on the dyno with Matt....
I did a thread in the DIY section on how to install the afm. But me being a northsider im happy to give you a hand or do it for ya if you need...
Is it true that Matt dose'nt like touching Wolfs?
Yes, he hates touchin Wolf's and will only do it if really needs doing.
Other then that, good to see another write up and good comments about Matt.
I'm gettin my z32 AFM shortly and will be requiring another tune!
Hoping to get this all done before Track day though :D
Autronics are his most favourite, then the fc he said.
when i asked him what ecu i should run (26/30 ~700hp, circuit gtr) he said fc over the autronic as the major advantage is the fc has a knock sensor, also will do everything it needs to
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it鈥檚 still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
