I've got a weird looking BOV on my R33 GTS-T. It's got a Mitsubishi symbol on it, and it's model number is K5T09. I've attached a pic.
I'm just wondering if anyone knows anything about this type of BOV. Namely whether they are adjustable? I cant see any way to do it, but someone else may know something I dont?
I'm getting a huge amount of flutter, even when on relatively low boost (11-12psi). It seems that its only when I get full boost (15psi) and back off that I get a proper vent, and even then it flutters after some pressure is vented. It's venting back into the intake. Is this 'plumbed back?' If so, should I be getting extremely loud fluttering?
Excuse my ignorance, I dont know that much about the bastard things :D
Any help would be appreciated.
https://www.sau.com.au/forums/topic/122905-weird-mitsubishi-bov/
Yeah mine is stock and has the Mitsubishi sign on it, don't worry your not special nor do you have a freak BOV.
Just a plain ol stocky
EDIT: Looks like there is a plate there also which is blocking off the air from "returning" so thats where your flutter is coming from, take that plat off the middle and re-attach it and you will find you have no flutter at all.
Edited by MADGT4
Interesting..I didnt think it could possibly be stock. A mitsu part on the top of a nissan engine!! :D
I know this stuff happens often, but it's fairly prominent aye! hehe
Thanks for your input guys.
Does yours flutter at all? how much boost are you guys running?
alot of car manufacturers use other manufacturers parts. on my mate's my01 rex, he has nissan window switches/relays.
its a usual thing.. i heard holden used a whole nissan engine :D
Hahahhahaaa Love it! =)
I found an interesting thread on SDU about modifying the factory BOV to stop boost leak: http://forums.skylinesdownunder.co.nz/show...=&postid=191358
I think I may have solved why my turbo wont flow any more than 15psi when its capable of 18-19!
if you have a FMIC and do that mod to your stock bov, it will flutter and not blow off as it should..
here is my response..
unbolt the bov from that adapter under it and bolt the bov directly on to the spot on your car.
There should also be a thin gasket between the bov and plate where you bolt it to the intercooler pipe (near the throttle body) on your car.
When you separate the bov from that adapter in that pic, take a look at the bottom of it.. there should be a small hole next to the big one.
Make sure it is “NOT” blocked.
Once you bolt it back on your car, connect the vacuum hose on top on that little nipple, connect the large hose to the front of the bov and tighten your clamps.
Should all be good now and no more flutter.
You’ll find your car will run smoother now too.
Ok, i've unbolted the BOV from the intake, and there is a thin gasket, plus a thicker metal plate that completely blocks the bottom of the BOV off from the intake! Is this normal?
BTW, that pic at the top isnt actually a pic of my BOV.. It's just one i found on the web. Mine doesnt actually have that thick adapter at the bottom, but it does have a thinner metal plate that blocks the bottom of the BOV as stated above...
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
