  • Replies 76
Originally posted by Duncan
Wow, great times there scott d. (for a 4 cylinder :D )
Didn't you get a chance to drive, typerlc?
No ... and I'm pretty dissappointed about that! Too busy collecting money, flagging and all that sort of sh*t.
And while I know you're joking Duncan, for the record, my stock ITR (DC2R or old one for the uninitiated) does low 12s with semis (I was hoping to say 11s ... I'm close, but not quite there yet). Of course track conditions play a big part in good times. And they weren't the best on the day (not bad in the arvo, but still cold).
How did your race go Duncan?
Low 12s is pretty bloody quick too, that's all I can do in the skyline. Those type rs are sweet handling cars, they just need a turbo :D
I should have gone to this instead, I ended up with 5th, 6th and a broken driveshaft :)
Good to see the numbers were better than expected.
Who needs a turbo with performance like this: http://www.vtec.net/articles/view-article?...ticle_id=101836
For those that can't be bothered following the link, it's a new ITR engine (4cyl, 2.0L, NA) making 260 WHP with more to come :)
I'm having second thoughts about posting this in the lion's den. Ahhhh ... you only live once :)
Well, that's a huge output there. approx 260kw at flywheel?
I do like to 170nm torque peak at 5,500rpm :D - wouldn't want to drive up a hill!
Seriously though, that is a huge power output, but you'd have to admit it would be pretty unfriendly anywhere except a race track.
I do like to 170nm torque peak at 5,500rpm :) - wouldn't want to drive up a hill!
Hmmm ... your math has gone awry somewhere. Torque peak was 173 lb ft ... ~ 234 Nm. Still not turbo-like, but nothing to sneeze at.
:uhh:
You mean they don't talk metric over there? 234nm is much better, but its where it comes in that worries me! I guess it revs to 9k tho.
You guys will see the light one day :)
Originally posted by red900ss
heh these are the lights they normally see  :uh-huh:
Hehehe.
Yep ... that's them. Why do skylines seem to always be on the brakes. It's a bit distracting when you're passing slower cars to have their brake lights always flashing you. At least they're courteous enough to pull over when they see a real car approaching.
In case that's not clear ... maybe it's time to refresh yourself with the results:
http://www.natsoft.com.au/cgi-bin/results....05/2003.WAKE.S1
:):P;) :bahaha: :D :D :D
(oh god, what have I got myself into?:))
Hey, how can hondas be so fast when you guys leave your engines in your basements?
http://www.skylinesaustralia.com/forums/sh...highlight=honda
Hmmmm ... Duncan, I'm sure that thread says more about Skyline owners than Honda ones. :D
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
