I have 18" 235/40 at the front, and 18" 265/35 at the rear.
My mechanic told me 34psi all round. (By the way, he's an idiot, wont be using him anymore. Stuffed my timing belt fitting. But that's another post).
My rear tyres look nice and pumped, but my fronts look a bit low.
What pressures do you guys use with same tyre sizes?
I know it's been asked before, and yes i searched, and read the posts, but alas, here we are.
Couldnt get a straight answer. Very differing opinions.
I am just using it for street driving, no drag, no track.
cheers ;)
https://www.sau.com.au/forums/topic/123584-tyre-pressures-for-18/
I use 38psi.
You can actually damage the tyres, on the inside, from having the pressure too low.
Is that for 18", similar size?
A friend of mine just bought an Ford FPV Turbo 6. He has 19" from the factory. The tyre placard says 38psi.
That's what got me thinking. Also the jarring shocks from the cr4ppy sydney roads feel awful through my front tyres.
The strange thing is that my rear tyres (265/35/18) look well and truly pumped at 34psi.
where as the front (235/40/18) look kinda flat at 34psi.
is this because of the different series?
I think i remember something about bicycle tyres, especially thin racing type, use a higher psi. Probably because there's less area to fill, so the pressure is greater inside. Not sure what the theory on all that is.
i'm going to try 38 at the front, but might leave the rear on 34 for now.
Running 38psi all round now.
Seems like a good call.
Apparently, low profile, higher psi. That's what i was told... here and out there. Even 40psi would be ok.
Has to do with the sidewalls being less able to support themselves, higher psi helps keep them in check.
something like that anyway. plus i'm running nankangs, and these have got weaker nylon sidewalls, apparently.
So cowie165, maybe 40psi was ok. Have you had any probs with uneven wear (in the middle) at that pressure over the last year?
Hi Tony,
The tyres are Federal SS595s with 7,000km and they are wearing evenly, which is great to see :happy:
The lack of sidewall flex you mentioned is the reason I was using 40psi. Hrmmm. As an aside, it's a higher pressure but lower volume than smaller size (15", 16" etc) tyres (ideal gas equation).
Mark
Since we are on kind of the same topic how much do you guys recommend on 235/45R17? Been using 38 guess Ill have to lower it now, just wondering would this actually ruin the tyres in anyway if you have it too high?
My concern would be bloating the tyre, and therefore wearing the center tread prematurely.
But lets see what Al says. lol.
You brushed on a good point there. A lot of guys new to sports cars believe that higher pressures = improved handling.
Whilst that may be true for your family mobile with a tyre placard suggesting 26psi for the Camry, sports cars generally already have higher pressures. Increasing them further bloats them just like you mentioned Tony and you actually end up with a smaller contact surface than if you ran them ~4psi-over-recommended. You need to find that nice happy medium :)
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
