I have 18" 235/40 at the front, and 18" 265/35 at the rear.
My mechanic told me 34psi all round. (By the way, he's an idiot, wont be using him anymore. Stuffed my timing belt fitting. But that's another post).
My rear tyres look nice and pumped, but my fronts look a bit low.
What pressures do you guys use with same tyre sizes?
I know it's been asked before, and yes i searched, and read the posts, but alas, here we are.
Couldnt get a straight answer. Very differing opinions.
I am just using it for street driving, no drag, no track.
cheers ;)
https://www.sau.com.au/forums/topic/123584-tyre-pressures-for-18/
I use 38psi.
You can actually damage the tyres, on the inside, from having the pressure too low.
Is that for 18", similar size?
A friend of mine just bought an Ford FPV Turbo 6. He has 19" from the factory. The tyre placard says 38psi.
That's what got me thinking. Also the jarring shocks from the cr4ppy sydney roads feel awful through my front tyres.
The strange thing is that my rear tyres (265/35/18) look well and truly pumped at 34psi.
where as the front (235/40/18) look kinda flat at 34psi.
is this because of the different series?
I think i remember something about bicycle tyres, especially thin racing type, use a higher psi. Probably because there's less area to fill, so the pressure is greater inside. Not sure what the theory on all that is.
i'm going to try 38 at the front, but might leave the rear on 34 for now.
Running 38psi all round now.
Seems like a good call.
Apparently, low profile, higher psi. That's what i was told... here and out there. Even 40psi would be ok.
Has to do with the sidewalls being less able to support themselves, higher psi helps keep them in check.
something like that anyway. plus i'm running nankangs, and these have got weaker nylon sidewalls, apparently.
So cowie165, maybe 40psi was ok. Have you had any probs with uneven wear (in the middle) at that pressure over the last year?
Hi Tony,
The tyres are Federal SS595s with 7,000km and they are wearing evenly, which is great to see :happy:
The lack of sidewall flex you mentioned is the reason I was using 40psi. Hrmmm. As an aside, it's a higher pressure but lower volume than smaller size (15", 16" etc) tyres (ideal gas equation).
Mark
Since we are on kind of the same topic how much do you guys recommend on 235/45R17? Been using 38 guess Ill have to lower it now, just wondering would this actually ruin the tyres in anyway if you have it too high?
My concern would be bloating the tyre, and therefore wearing the center tread prematurely.
But lets see what Al says. lol.
You brushed on a good point there. A lot of guys new to sports cars believe that higher pressures = improved handling.
Whilst that may be true for your family mobile with a tyre placard suggesting 26psi for the Camry, sports cars generally already have higher pressures. Increasing them further bloats them just like you mentioned Tony and you actually end up with a smaller contact surface than if you ran them ~4psi-over-recommended. You need to find that nice happy medium :)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
