I just had the 100,000km service which included having the trans fluid changed. Since then it seemed as if it was shifting slower and that sometimes the revs would flair between gears.
Then tonight under hard acceleration when changing from 2nd to 3dr it just let go, tacko hit 7,500 rpm and the power was not getting to the wheels.
Its fine changing between 1st and 2nd when I have the shift leaver held in 2nd and if I hold it to about 4,000rpm and then move it to drive with the throttle closed it changes into 3rd ok. The change into 4th seems ok as well.
The trans fluid smells like burnt rubber now.
I know MV in Adelaide are the experts on these but can anyone recommend someone good in Melbourne who can replace the bands and clutches with heavy duty items and fit a shift kit?
Edited by Burns
https://www.sau.com.au/forums/topic/123609-my-auto-is-stufed/
Check and make sure there are no leaks of A/T fluid. Check oil level.
It willcost BIG BUCKS to fix. I just paid $4k on a Subaru. Do any of the Skyline boxes fit?
For about $12 get a bottle of Nulon for A/T. It may keep you going till you get it fixed.
oh the sliptronic auto... time for a manual conversion.
My auto did the same thing once, after a night of going crazy off the lights after i first got the car. Didnt want to play the game. i drove it home.... verge of tears... woke up the next morning and drove it to work - it was fine! tight as a drum. was like the damn thing just healed.
May have just been heat?
Is yours still playing up?
My auto has its good days and bad days.
Some days, it shifts soo quick i get a slight chirp on gear changes.
Some days, it shifts so slow on gear changes that I get have this thing where if i change from 2->d, the revs jump about 500rpm while keeping the same gear, then i hit the rev limiter while in D, then it changes.
On another note, its my 2->3 gear changes which are worst. Ive gotten about 1-1.5 full seconds of slip between changes....then the next morning its just been fine?
As above, check ATF
overheated fluid, incorrect fluid level (too much or too little) are 2 main things that will affect their performace. getting the fluid changed can sometimes cerate problems with the auto trans fluid filter being clogged, then the clean fluid loosens all these particles. take it to an auto trans specialist and get them to service it properly, not just replace fluid.
Nope it’s stuffed not just a bit of slippage or heat caused. The fluid level is spot on and I have a big trans cooler fitted. I took it for a little drive just before and it changes out of 2nd but not into 3rd. It just releases 2nd then free revs not changing into 3rd. When I slow down or change it back using the stick it goes back down into 2nd.
I have 1st, 2nd then neutral revv revv and go no where.
When I had it serviced they also fitted an adjustable cam gear, spit fire coils and gave it a tune so it’s putting out about as much as you can with a stock turbo.
I think the flex band or clutches between 2nd and 3rd have gone.
So am I the first to break a Stagea auto?
I will give Keas a call tomorrow and see what they think.
Edited by Burns
sounds like the bands need tightening, used to be the same on my old vl turbo auto, not fun when it slips like shit to the revlimiter everytime u put ya foot down or when it kicks down :P
I find that my auto changes are a bit sloppy when it is cold. Once I've been driving for a while, and the trans warms up, it seems to tighten up and changes become a bit sharper.
Sometimes it gets confused when I accelerate quickly out of an intersection and throttle off before it changes, it seems to hang for a bit and then change.
Auto's are all black magic, smoke and mirrors to me. At least I can visualise what is going on in a manual box when I change gear.
After I fitted my FMIC I found, what seemed to be, a loss of power which I thought was either lag from the new piping (yeah right) or that my boost control valve was playing up. After some inspection I found the the boost level was actually not changing when this was happening. This usually occured under semi-light throttle with about 0.2 bar boost.
Then I started noticing that it was taking a looooooooooonnnnnngggg time to change gears when I had the foot up it. On sunday I attempted to pull away from an intersection & found that I had barely any drive, I backed off the throttle & reapplied it to find it was there again. Today after giving it a squirt it SLAMMED into the next gear after holding between the gears. Not a whole lot of fun really. Still, it does give me more reason to do the manual conversion now :D
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
