OH! makes me think i should have taken pictures from when i moved house today! stag was CHOKERS!!!
Same, when i moved, managed a fridge(in box). also managed a 46" TV(in box) plus all the other crap.
Very Nice!! They look so nice in black.
Flip the little cover over the positive terminal or it wears thru the underbonnet heat padding stuff :)
Yeah I was charging up the battery and forgot to flip it back ....do you guy's know the color code of the dark blue for the 1998 stagea 260rs?
If you put the vin # into FAST it will give you the paint code.
If you dont have FAST PM me ya vin and i can do it for ya.
It should be on the factory ID plate below the model number(my guess is BT8) but put up your vin number otherwise for the definitive answer.
I sold my RS4 S on Friday, took one last pic before she got picked up. :D
what offsets are those? thats exactly how i want the wheels on my rs4s to sit, what did u use?
9.5 +15 all round with 235/40's
I have the wheels for sale, PM me if your keen.
i'm so poor its not funny, did u have any issues with clearance? did u have the guards rolled or anything?
Looks awesome. Pity the RS4V's don't have the same rear cradles to run rims with that sort of offset. I'm trying to squeeze 9.5 +25's under mine....
i'm running 9.5+15 on the rear of mine no problems at all.
on another note, just ordered my new wheels, so 4 months-ish (such a long wait :banana: ) and you'll see some more crazy wheel fitment :banana:
do tell mike...pm me if its a secret
Its all good! Only issue I had was the wheels would sometimes hit the coilovers but that was because I ran the car so low.
I would have prefered if the wheels had a +5 or even a 0 offset and ran the same camber all round (around 3 degrees)
on another note, just ordered my new wheels, so 4 months-ish (such a long wait :( ) and you'll see some more crazy wheel fitment :laugh:
What suspension are you running? I've got a set of Tein Style Master Super Low down Wagon Spec.... stupid funny names! My biggest issue is that I can't get the front end any lower. The rear I can drop another 2". Did you roll/pull/pump your guards to fit the +15's? Do you run camber arms?
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
