  • 4 weeks later...
  • 1 month later...
There's no doubting some tender love and care has gone into this ride. Not to mention some serious hard earned ....
Soz for picking a fault, but when you eye something this nice, any spot or blemish stands out like dogs balls.
I'm sure in time you will grab something nice to complement the rims and complete the package.
Looking good Darrin.. mine goes for paint real soon... what the go with your roof rail holes?
Bloody roof rails. We have been waiting for the replacements ones for over 7 months
The ones on there are the factory roof strips painted out with the rails removed, hence the 3 holes
:) At least he has the rail trims! Check out my car next to Darrin's: all I have is surface rust and race tape. Damnit: now I've started on the "roof rail rant" again! :banana:
less whining, more interior pics
Looks good samkoek!
Darrin - Just looking at your Stag again, have you ever considered fitting a set of Bride/Recaro's? Would finish the look off nicely!!!
Also, for those who have painted their standard roof strips, is that going to be suseptable to rust or anything?
Looks good samkoek!
Yep, I have 2 pairs. Brand new pair of red recaro Milliniums and a vgc pair of Mits Evo 8 factory recaro's
No rust issues painting the strips as they are s/steel cover in plastic/rubber stuff. You still have the holes to fix thuo.
The blue one above has a Masa rear bar and sides, same as my car. Wing not sure.
hi guys, thanks for your comment, i am not sure what front bar it is, but is look same as the RB26 stagea one i guess, and the side and rear is MASA i guess too. i bought car like that. i like the colour, it stand out. everywhere i go and the people always look at my car , hehehe. Make me very uncomtable..shy..
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
