hey ruby rs4, luving the black series 2, is that how the car came, with the front bar? is that just a standard nismo one is it? wat about the grill? did you paint it black youself?
the bar is from vivagarage.. how'd it fit roo?
the grill is standard
visited the parents and tested out their new camera. canon sx1. tell you what it takes a nice photo for just point and shoot auto mode, and the HD video is good too. after taking photos, realised camera was not set to "fine" mode. bugger.
Edited by Jezboosted
No. My S2 originally came with a Dayz bodykit. I since removed it and fitted a Dolphin kit and now I changed the front bar, yet again, for an Aero type M bar from Viva Garage. The grille is standard, I just took the double unicorn off. Got a Viva grille coming.
Altho my S2 came with Nismo badging on it, I'm trying to figure out what makes it so "Nismo" special? It has a Momo wheel, and some chrome handle on the back of the tailgate, Nismo badges, it did have GTR style rims (since replaced with 18"), but I'm still yet to discover any other items. I've seen a "Nismo" special Stag on ebay, but his looks more stock than mine (it doesn't even have Nismo badging). So I reckon mines a proper Nismo stag, but not fully aware of all the Nismo touches I'm sure.
noticed you've changed your front bar ruby, is there some place that makes them or somthing ?
Yep. Viva Garage here in Adelaide :)
roo that bar looks rather Viva garage like? How is the quility of it and was it direct bolt on?
Are you leaving it matte?
I drilled all the required holes myself and it bolted on no problem, altho the indicators took a bit of fiddling to fit.
No, I'll be painting it gloss black, but couldn't get it into the shop before the car show this weekend. So it goes in matt black for now. Didn't want to do a rush job.
I've been thinking about getting the entire Stag resprayed Satin Black. :laugh:
Edited by RubyRS4
That Viva bar looks great on your car mate and you pic just helped me heaps..
I have a S1 with the same dolphin kit and have been tossing up weither to get a Viva Type M bar or another Monkey Warehouse Nismo bar as mine is cracked to the sh!thouse and your pic just made up my mind :(
Edited by SHIZNT
i realise this, however he bought a copy locally from viva >_<
I realised that as well, my response was more for BCK34 as he saked what style the bar is.
MIKE have you worked out what re-spray colour your car is?
i'll pm you also, but im pretty certain it is 'athlete silver' (i believe that's kv2?) it came on bnr34's
nice stag bubba, ok peoples so after waiting nearly 2 months i have finally got my new rims on my stag hope yous like, (and if ya dont, TOO BAD i do hahahah)
I've got a nice lip that would fit nicely on that front bar of yours :)
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
