Does anyone have any feedback on ADVAN performance in Silverwater. Took my car to get it dyno tuned and they said pump is at its max flow and leaning out too much...so they recommended going with bigger pump to be on safe side bosch 044..had a nismo one in place b4 recommendation.
my question is they said to me car would be ready but on the way there to pick up car..they rang and said it wont be ready and the car was still leaning out too much...should i have to pay them extra to find the fault? when they have already added the pump in. I understand if its not related to the pump at all, the cost i should pay for as want the car to be 100%...but if it was to do with the pump and the way it was installed..should i pay for it for them to find the fault? any thoughts.
aaron
https://www.sau.com.au/forums/topic/123865-workshop-experience/
If they fitted the pump and its still leaning out, it might not have been the NISMO pump you had in there making the car run lean. What hp is your car running and is the nismo pump you had in there rated at what hp?
not sure what rating the nismo pump is rated at..think its 125%..so think 25%more than stock....car was making 330rwkw on 16psi...sard injectors in there....does anyone know what the nismo ones is rated at?
They are a pretty quality workshop.
It may be that the pump is out of flow but as mentioned, if it's still leaning out with a bigger pump then maybe something else is wrong.
yeah but if they find that it is something else then do i fork out the 550 for the bigger pump (installed) when it wasnt necessary to have in the first place? thats my question...if that if fair for them to do tho.
at the start when they tried to tune it..my PFC was older version they had to get it sent to them from NZ..would the PFC program version that was used was wrong???
That sounds strange to me, the Nismo pump from memory is 276L/Per hour and should be find for that power level.
I know cars running over 400awkw with the Nismo drop in pumps without an issue.
As far as I know, the Bosch 044 flows something along the lines of 330L/Per hour.
What size Sard injectors are you using?
It sounds to me like something else is going on, however Advan is a very reputable workshop so im sure there is a logical explanation.
Nick
I find it hard to believe the nismo pump was causing you to lean out unless it was old and buggered. How much hp are you estimating to end up with from this tune?
Older versions of PowerFC are pretty common in R32's the only difference I know of is in the hand controller version you need to use with them. I suppose there could be other differences as well I haven't looked into it closely. Maybe he needed to send a hand controller over from NZ.
a BNR32 GTR nismo fuel pump flows 4600cc/min. that's 766 per injector. so if you are using sard 700cc injectors your pump can amply supply those injectors at max duty.
i really think the best thing to do is talk to them. they are the only ones who can shed some light on the situation. just ask them the questions you want to ask here. perhaps it was just a simple misdiagnosis, or perhaps your fuel pump was knackered. perhaps it wasnt really a nismo pump in the first place. either way they are the ones with the answers you want.
ive got sard injectors think they are 680cc ones in there with sard regulator....the the PFC has already got the hand controller in place there...they didnt have the older version n had to get it sent to them. Yeh maybe the pump wasnt a nismo item at all...whats the stock GTR pump good for in relation to RWKW? Mine was making 330 @16psi and they said was leaning out, so went with bigger bosch one. Hopefully they will have it worked out
need the car for this weekend. thanks for the input guys
stock pump is good for 550cc injectors (or approx 540 hp at the engine)if it's in good condition. have them flow test the pump they took out to determine if it was a nismo pump, or just a stockie.
edit: pretty sure that's right. stock pump is 196 l/h. or is it 220. cant remember. either way it's too small for injectors near 700cc.
Its begining to sound like you may not have had a Nismo pump at all, and if this is the case than Advan recommending you fit an 044 sounds perfectly normal to me.
yeh but they put in the 044 and said to me its still leaning out and now they have to find where it is, which will cost more doing so. So my thought was what if it wasnt the pump at all and got it replaced for nothing.
Thats a hard question to answer, I would be patient and discuss the issue directly with Peter or Brad at Advan
yeah just call back from peter...and it was the new fuel pump that they had put in was faulty....and now has been replaced with a new one....So do you guys think that i should foot the bill for that, i mean they changed the pump and it was faulty and had to find the fault and turned out being the new pump n now have replaced it.
Iam resonable in that if it was to do with sumthing else i wouldnt ask the question...but since it was the pump being faulty ..do you guys think would be fair for me to pay for the diagnosis that they had to do to find the problem??
aaron
aaron
No i wouldn't,
its up to them to provide the warranty on that if they sourced and installed it, so the time it took to diagnose that the pump THEY installed was faulty, is up to them to foot. Of course the original installation and pump price would still have to be paid.
There is no warranty on performance.
Once you accept it, life is a lot easier.
so if lets say a performance shop does something and doesnt do it correct your willing to pay for it? I'll pay for a service to be done 100% and no less, and why would anyone expect anyless?
Anyways it was clear today what was happening with the fuel pump the first one they put in was faulty and had to use another one. so all good and picking up car tommorrow....and no bad intentions was towards ADVAN at all Peter has been very helpful and good in getting this problem solved.
In your case they DID install the pump correctly... Dont go off on an unrelated path :happy:
Pump - installed and was faulty.
Bosch warranty covers the cost of the pump (i have one sitting next to me with the warranty seal on it.)
It does not however cover the labour cost, which is unrelated to the installation going by what your saying.
I would expect to pay the diagnosis cost because... there is no warranty on performance, only some of the parts... and then subject to condition.
and this is yet another example of why i wont put a bosch pump in my car. i dont know what it is but lately i've heard of so many bosch pump failures and the pumps being replaced under warranty. yet i've never heard of a single nismo pump failure. sure the bosch pumps flow the numbers but they are more time consuming to install and dont have the best reliability rate in my experience.
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
