  • Replies 158
Decided to create a consolidated thread for everyone to voice their opinions and ideas here. From now on any one posting about opinions on the following items will have their threads merged into this one:
- what headunit to buy
- what speakers to get
- alarms
etc
Any other questions (eg problems, technical advice) will remain as they are.
Cheers,
Vijay
  • 3 weeks later...
Ermm... what kind of solvent? If you know of one that will take the goo off but not eat my paint or damage the rubber door-seal, i'm all ears!
Cheers!
wax and grease remover..
http://www.caraudioaustralia.com/content.php?contentID=19
hi guys,
i have a jvc headunit atm
running 2 150watt 6.5" mtx tdx6502 2 way speakers
with NO speakers in the front atm
got a 2 ch cadence amp in the boot
which combination would you guys reccommend?:
1.put new 6x9s in the rear and chuck the 6.5"s in the front,
which is going to need alot of customising with mdf ( after reading a few threads in the forum)
and get a new subs later
2.just leave the 6.5"s in the rear and buy new subs?
buy front splits later
i normally jam up rnb and techno (which needs ALOT of bass)
any help will be appreciated
thanks in advance guys
ryan :blush:
I have to get a few things on my car fixed and am going to upgrade the stereo at the same time so I was after some advise...
the car is a r32 GTR and what I've been quoted on is this:
Clarion mp3/usb headunit $310
Clarion 5" splits for the front $110
Clarion 6.5" 3 way rears $100
Clarion 12" Sub $190
Clarion monoblock amp $220
Fitting + cables etc $250
now origonally I was going to have 2 or 3way in the front and 6.5" splits in the rear with a 4 chan amp with 2 chanels bridged to drive the sub...
the salesman talked me out of this and sugested the option I listed.
so whats the go? or do you have a better suggestion for me?
brilliant idea.
lock my thread and ask me to ask my Q here for sweet fruck all response
Edited by Betz
  • 4 weeks later...
Ah yeah, I run a newer amp now... the JayCar 100wrms unit, which seems to drive them just as well as my old (large) amp. I have the balance faded to the front (+7), and the JBL's still flop around like crazy. I'm running the higher end crossover, so they are hardly getting any lower frequencies. This has stopped them from throwing the coils, but now have ZERO bass.
I might get another pair of Clarion splits, as I had suggested... $200 new, I can find them for $100ish nowdays... the new models have brought the older ones down.
Hey, if you really want to install a proper system you MUST have the same brand and series of speakers in the front and rear. They don't necessarily have to be the splits but they must be a Clarion speaker from the same series. As you don't need split's in the rear, a clarion 2 way coaxial 6.5" speaker (from the same series) would probably be a good choice.
The reason they must be the same front and rear is they must be made of the same material (to really sound good), and have the same crossovers or you can end up with phase issues.
The sub can be a different make of speaker but the front and rears must be the same. If you want any real bass or volume you definately need a seperate power amp. Contrary to popular belief your amp should always be rated higher than you speakers.
brilliant idea.
Yeah I see what the sales man is saying, you want your splits in the front with the treaters mounted on the dash board (facing you), as this is where all your high end comes from. Split's in the rear are a complete waste of time, the rear is really only used for fill. You want most of your sound (especially the high end) comming from the front.
I'd go the 5" split's (or 6" if they fit) in the front, and either 2 or 3 way 6.5" coaxials in the rear.
The clarion mono block amp sounds fine, but I would also definately get an amp for the front and rears as well.
  • 1 month later...
if you want equipment stuff i would suggest
decks -
alpine
kenwood
jvc
coax's/splits
mtx
kicker
earthquake
bostons
alpine
subs
audiobahn
mtx
alpine
earthquake
kicker
amps
earthquake
alpine
kenwood
soundstorm
jbl
stuff i have had problems with
- rockford fosgate power series 6.5 " coax, there top of the range coax's 2 sets
- pioneer deck + pioneer speakers + pioneer mono block
- sony.. only thing that compares to pioneer for cheaply made china crap at overly expensive prices.. but her it looks pretty
- fusion subs 1 tore a surround and another just stopped working
- pyle mono block (was great while it worked but shorted out very easy)
- cadence rca cables, they are crap, look awsome but really poor workmanship, friend also had problems with his cadence amp cutting out
- boss audio subs, haha what a laugh u buy them to blow them up just for something to do
any way i hope i helped some people with there descisions
also what to look out when purchasing equipment
power ratings can be very descieving as companies like pioneer sony etc throw on brandings like 400 watts or 350 watts which is peak power, all these ratings are false, as they cant run on peak power for more then about a second or 2 before they will blow, same as amps subs etc
generaly with the most common brand name stuff like sony kenwood pioneer etc they speakers are usually about a quarter or less of what the peak is, so how can you make sure how powerful they really are? check for nominal power rating or continious power rating aka rms this is the best indicator of how much power they can handle, generally for an average system about 50watt rms will be more then enough for your 6"s and about 60+ should be nice for 6x9's, subs you want to have at least 300 watt rms or more to have enough kick
with amps you need to be very careful as underpowering your speakers will cause sound clipping and damage you speakers, how do you know if you have sound clipping? you will hear when you crank up the volume, distortion and loss of certain sounds or a jerky inconsistant sound.
how to make sure your amp can run your speakers? as mentioned before look at rms ratings not peak power, so if you have 2 sets of 60 watt rms speakers you will need a 4 channel amp which around 70 watt rms x 4 and just leave the gain down a little, with subs same again if you have a sub which is 400 watt rms you will need an amp which is say 350-500 watt rms to power it properly, you also need to keep an eye out for a thing called Ohms too, i beleive it is a rating of ristance/current, so how does this work? well most rms ratings are at 4Ohms for car speakers some times may be rated at 2 or 1 or even 8, basically easiest way to work this out is say something @ 4 Ohms is 500 watt rms, 2 Ohms will be double the value so will go upto 1000 watt rms @ 2Ohm, and 2000 watt at 1Ohm and if it went upto 8Ohms would be 250 watt rms
BE CAREFUL!! not everything can run @ any ohms some amps may only be able to do 4Ohm and some may be able to do anything you want safely so make sure the ohms rating and power ratings all match up before you purchase your product as poor product selection will resualt in bad sound and possibly speaker damage
as for wiring, always make sure you rca's and speaker wires are not near your power cable, your ground wires always need to be either same size or larger then your power wire
for general systems your single 8awg wire will be enough to run 1 or 2 amps under about 300 watt rms each, as you start getting bigger you need to look at 4awg to 0awg which is the fattest, and remember make sure you ground is bigger then the power!! example if you have 8guage wire from engine to amp you will need at least 8 guage as a ground to the amp, or even better 4 guage!
if any one has any questions or did not quite understand please feel free to ask, and if any one disagree's on what i have said, i am not a professional, just what i have learnt in the last few years wasting on money on audio equip and installing
thanks for reading hope i helped :)
Yeah I agree with what your saying, esecially with regards to power ratings.
As you said only ever look at RMS ratings (peak is a crock), and make sure your amps are rated at least a little higher than your speakers.
Only thing I would disagree with is some of your brand preferences (although I guess it partly comes down to personal preference):
Highy end decks
I don't like kenwood
JVC and Clarion are good
My preference would be alpine
coax's/splits
mtx (don't know)
kicker (Good)
earthquake (Good)
bostons (Excellent)
alpine (Good)
My preference for speakers would DEFINATELY be Focal
subs
audiobahn (Don't know)
mtx (Don't know)
alpine (Good)
earthquake (Good)
kicker (Good)
My preference for subs would DEFINATELY be Focal
amps
earthquake (Good)
alpine (Good to high end)
kenwood (Don't like)
soundstorm (Don't know)
jbl (Good)
JL also make some of the best amps around and would be well worth considering
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
