I am not sure that I understand what the fuss is all about with changing rotor diameters and the effect that has on the pad shape. Sure the inside and outside radius of the pad will be ever so slightly different to the inside and outside radius of the rotor. But is it such a big deal?
The first picture Roy posted shows that he could have used a 2 mm larger diameter rotor with those pads. Noting that there is not really much of a problem with the different radii.
If you are currently using a 280 mm rotor (R32GTST) then you could be using pads shaped for a 280 mm rotor or a 296 mm rotor. There are far more compounds available for R32GTR’s, hence 296 mm rotor. So if you buy GTR pads for your GTST (with its new 324 mm rotors) you are only talking about a 28 mm increase in diameter from where those pads are designed for.
Hardly a big deal, since the same pads work OK on 280 mm versus 296 mm ie; a 16 mm difference.
The next step up would be to use the R34GTT pad which, being designed for a 310 mm rotor, would just about fit perfectly on a 324 mm rotor. I haven’t actual tried R34GTT pads in an R32 (GTST or GTR) calliper. But that could be the answer, to what is not really a big deal anyway.
:D Cheers :D
  • Replies 87
Posted Images
I spoke to Race Brakes Sydney and they will do the 5000series 2piece for $450ea or 4000series 1 piece for $245 ea better for a group buy.They told me to have a look at the db1170 and db1199 bendix pad and you will see the pad material sits lower on one pad than the other this may or may not be the secret of pad overhang.They are also happy to organise group buys if we can get anything together let them know.They do AP kits and also have the caliper kits for the nissan 4pot calipers and 1 /16 brake master cyl kits as well.
Thankyou very much for the explanation, much appreciated and very logical!
I will get a price for the DBA 5928-1 tomorrow and see where it sits.
Cheers,
Caz.. :action-smiley-069:
Hey Caz,
Did you manage to get a price on this??
Thanks
Dane
Any word on the 33GTS25t adapters for the 324mm disc? Also would these adapters mean that you cant use your standard spare tyre on the front of the car?
cheers
Evil
Edited by EvilINGT
My calliper brackets arrived the other day, they look good
1. solid construction
2. nicely machined out of the appropriate alloy
3. steel hellicoiled threads
4. High tensile allen bolts and spring washers
Picture follows;
I am going to use them with the DBA 5000 series rotors, which I picked up at oran Park last weekend.
Picture follows;
Hopefully I will get some time tomorrow to fit them onto the R32GTST, take some pictures and post them up.
:miner: cheers :rofl:
  • 2 months later...
Has anyone been incontact with caz, i have pm'd him and got no response. I am keen for a set as i have some 324mm rotors here. just a question though, will they fit under the standard 16" wheels on a 32?
not a chance
Do you have R32GTST or R32GTR?
Because the current kit won't fit R32GTST's, Caz is currently working on a new kit for them.
:laugh: cheers :mad:
:P cheers :woot:
do they work on GTRs though? that's a bit of a shame :( I thought they had been tested/developed for GTST too?
:( cheers :no:
Did you get the last set SK? Any idea on how long untill there is more as per your pics for the r32 gtst?
Cheers :P
  • 9 months later...
hoping this bumps gets this thread some attention....
i want to fit 324mm GTR rotors to my R33Gtst with standard callipers and need the brackets (well depending on how much they are - if they're not too expensive, for sure, if they are, well i don't think the gains will be worth it - but anywaaaaay!)
so does anyone know where you can get this brackets from and approx. cost??
Cheers
I used the Unique Autosports calliper extenders and brake scoops on the R33GTST for the recent SAU day at Wakefield with DBA 324 mm 5000 series rotors, Nismo braided hoses, Castrol Response Super Dot 4 Brake fluid and Bendix Ultimate pads. No problems locking the brakes on demand using Yokohama R tyres even after 2 consecutive 15 minutes sessions. No fade, no shudder, no problems on the day or since.
I will post up some pictures of the installation process and the finished result when I get a chance.
:laugh: cheers :domokun:
yep UAS make and sell them. sure they may not be dirt cheap but they use good materials, and have done all the testing and design work for you. www.nismo.com.au
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
    • Great weekend and event. Open fire at the caravan park, perfect weather all day and a great feed and a couple of drinks at at awesome country pub.
