Not all the time But When taking off in 1st or 2nd I hear a grinding noise coming from the passenger side of the engine Not sure what it is, But I know it should be there
When I turn the car on I hear like a funny knocking sound from behind the radio?? Very weird sounds like morse code.
Also Stupid question but how do u turn on and off the fog lights?
Whats the best way to brighten up the dash?? i can hardly see my revs and speedo at nite time, my old dash in the silvia was very good.
Think thats about all other then that its a 1994 R33 s1 RB25DET with about 980000 on the clock.
Edited by faz
https://www.sau.com.au/forums/topic/124115-just-got-my-r33/
That "knocking" behind the radio sounds like a common fault in 33's which has to do with the aircon unit, do a search and it will surely come up with some results. To fix it, you need a $60 odd part and a bit of patience but it is doable
https://www.sau.com.au/forums/topic/124115-just-got-my-r33/#findComment-2291818
If you mean clickign by knocking, it's a very common problem and apparently its a plastic cog thats had some gears sheered of it. Also i've herd to much effort to go to for fixing.
And yeah my s1 doesn't have foggies (driving lights) theres room to put them in but you will have to run wireing as i'm pritty sure there isnt' any.
Michael
https://www.sau.com.au/forums/topic/124115-just-got-my-r33/#findComment-2291986
Re: dash lights not bright enough
I apologise if I'm stating the obvious, but R33s have a dimmer switch fitted during compliance. This means the dimmer could be hiding anywhere - have you found it and made sure it is on max?
If you have, it's fairly straightforward to remove the dash and swap the bulbs over. Most guys ditch the 3.4W stock bulbs and use 5W instead. With the dimmer in the R33s you can't go wrong. :laugh:
https://www.sau.com.au/forums/topic/124115-just-got-my-r33/#findComment-2292724
yeah dash lights should have a dimmer switch/dial... most likely just to the right of the steering column. On some cars turning it down makes it brighter.
Foggies were an option. Some S1 have globes in em, Some don't. If you have them from factory you should have another dial right alongside your headlight dial. I dunno the technical terms :)
https://www.sau.com.au/forums/topic/124115-just-got-my-r33/#findComment-2292926
Foggies were an option. Some S1 have globes in em, Some don't. If you have them from factory you should have another dial right alongside your headlight dial. I dunno the technical terms :whistling:
Are you talking about the lights next to the indicators on the frontbar? My ones turn on but they're not bright enough to be foggies, I've always assumed they were extra parking lights as the ones in the headlight aren't that effective
https://www.sau.com.au/forums/topic/124115-just-got-my-r33/#findComment-2300868
OK... series 2 SHOULD have a dimmer installed. It was required for compliance. My car has been in Australia for more than 6 years, and it has it. (funky 80's amplifier dial!)
And yes, the lights next to your indicators are your DRIVING LIGHTS... they're not called fog-lights anymore. Europeans have fog lights for... fog! And they'd be a bright yellow. Ours are just white and only light up the road immediately infront of you, and more out to the sides.
Driving lights and fog lights are weak to drive with, sure, but they are quite bright to oncoming traffic. They are supposed to be used like headlights. i.e: not in suburbian areas, and not with cars infront of you or oncoming.
Series 1's might be dimmer than series 2 though... for those s1 owners that have them.
Noone has mentioned the grinding yet, so i'll take a stab at that one. Check your engine mount on that side. If not that, check your bushes or have pedders or something check them for you. =-]
https://www.sau.com.au/forums/topic/124115-just-got-my-r33/#findComment-2300950
I wonder what the Road Traffic Act says about driving lights. From memory, the $70 fine was for using fog lights - I had a mate argue his way out of a fine when he produced the owner's manual that called them driving lights.
https://www.sau.com.au/forums/topic/124115-just-got-my-r33/#findComment-2301325
when i didn't know which places were good, i tried pedders.They knew less about skylines than the japs know about common-bogan-dores
https://www.sau.com.au/forums/topic/124115-just-got-my-r33/#findComment-2301875
tink its another one of those some have and some dont parts. i got them on my s1 coupe, had to take to them with a saw to fit in my cooler but still work. and i have had a aftermarket dimmer switch fitted and also the park lights next to the head light were fitted for compliancing. looks like they were drilled out with a hole saw and lights fitted.
https://www.sau.com.au/forums/topic/124115-just-got-my-r33/#findComment-2308386
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
