  • Replies 76
With the amount of 13 year old kids on ns.com we may have a hard time :) but we'll still win
I'll be in, depending on time of match :domokun:
-sigsputnik
-Let Me Drive
-R34GTX
-Adrian82
-dezz
-silver gts-t
- R33_Beast
- Rekin
this is for source.
i think servers are bookable for free. there are others other than these two. but 3fl is australia-wide.
e.g. gamearena:
http://www.gamearena.com.au/getconnected/s...reate/index.php
Edited by sigsputnik
i got a ADSL2 connection with 24000/1500 (so its 3 times quicker then cable on upstream) ... but I don't have any of the counter strikes installed on my new laptop. Don't know where the cd/key is either. Only got Battlefield 2 and Quake 4 on it at the moment.
Ok back to the real topic guys - gotta get a server and time sorted. Monday 9pm looks best atm so can someone chase up the server booking and then post details in the thread?
GameArena, 3FL, NetLogistics, Internode, - as long as it's a free booking any of them should be good.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
