Hey peeps
I went to get the car tuned with the new turbo/injectors put in today and the car is blowing heaps of smoke.
I am iffy about the bloke who put the turbo itself on (car was then towed to tune place) and am thinking maybe he messed up the oil line to the turbo or something?
The first impression from the dyno tuner was its the oil seal on the turbo however the turbo is apparently very near new (ie no shaft play and low kms and very clean).
I am curious what the problem could be?
Any suggestions would be appreciated, turbo will be taken off on monday and if we can't figure something out with what to look for ill have to pay for it to be sent to GCG and any repairs :D
Thanks for any help people
Regards
Jazza
  • Replies 52
Posted Images
If the oil line is too big, then it could be blowing the seals out on the turbo. Check and make sure the correct feed line is on the turbo, if not, then you might have gotten a turbo that wasn't in as good a shape as you were lead to believe.
is it plain bearing or ball bearing? they need to run different restrictors on the oil feed depending on the bearing type. Im guessing its a ball bearing? in that case the stock oil feed should be fine with its corresponding restrictor
GCG Hi-flows are B/B turbos, they gave it a rough tune (as i had boost control problems aswell) so the car will run with the gtr injectors and new turbo however it smokes even on idle!
The smoke is white and i will get custom braided lines for the turbo if its an oil line problem but i wasnt sure if that could effect the oil seal!
Same amout of water in the radiator and over-flow bottle as normal...
The tune shop said it was an oil problem, but the previous owner of the turbo is well known and gaurentee's me it was fine when he took it off his car and didnt blow any smoke, so im leaning towards oil lines but i guess i have to wait until monday to see that.
I had this problem with my car. it ended up being the bottom end :) its weird and it would blow HEAPS of white smoke on idle yes ??
Did this happen as soon as you turned the car on ? or only after you got it tuned ?
also check the oil breathers. pcv valve etc.
ive seen on to many ocasions people putting catch cans on incorectly efectivly sealing up the motor.
the turbo is the first to show blowby or posative crankcase pressure. in the form of thick white smoke :)
There are four possibilities here, and I have had all of them at one time or another.
1/ There is just too much oil pouring into the turbo because the oil restrictor at the inlet fitting is missing. There absolutely MUST be a pin hole restrictor, usually 1.0mm to 1.5mm in size to restrict flow when using any BB turbo.
2/ The oil just cannot get out of the turbo because something is wrong with the oil drain pipe. Pressure builds up inside the turbo, and it will force it's way out past both seals, even with a perfect turbo.
3/ If the bearings have a lot of radial play (the turbo is stuffed), then the oil seals are just not going to be able keep the oil in.
4/ There is massive pressure buildup in the engine sump due to blowby past the rings. The engine will be VERY oily and this should be fairly obvious too.
I would go for number one. Remove the oil inlet fitting from the turbo and have a real close look at it. There will be a very small hole. If the oil pipe just runs straight into the top of the turbo with a big hole, then that is your problem.
Less likely, but remove and inspect the whole turbo oil drain line and fittings. You absolutely must be able to roll at least a 10mm ball bearing all the way down that pipe. If you cannot, find out why and fix it.
Stuffed turbo bearings will be very obvious, and need no further comment. Really bad engine blowby and sump pressure buildup should be pretty obvious too.
The car never ran an ounce of smoke and has had regular oil changes, its def not a bottom end issue its only happened since messing around with the turbo, injectors, afm, catch can and ecu!
Interesting... i had the catch can modified so that i could block the gas's going into the intake before the tune but the car never ran with the catch can like that!
It used to have 2 lines running to it from the head but the other lines still connected (so it didnt really do anything at all...) now i got one line running to it and the other line on it is a breather (maybe this doesnt work and i need a catch can with breather built in on to of it? The air filter now has no gas's running to it as its blocked up and im not sure about the other manifold side of things as he spoke of blocking that via something too but i cant tell...
Pictures are below to explain what i mean!
Should i go buy a new catch can so i can have two lines running from the head to it (maybe one isnt enough?) and have a breather on it standard as this one didnt as i said it had an inlet modified to have a breather on it which maybe doesnt do the job?
Edited by jazza08
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
