Hei guys just received news that my car is being unpacked today. Dont know i will have the time to go se it or not this weekend if not i will have to wait till next friday. Hope the car is good ETC. Will keep you guys posted and hopefully some pics by then.
https://www.sau.com.au/forums/topic/124479-my-car-is-in-the-country/
  • Replies 128
Posted Images
oooo the moment of truth... first sighting of it in the flesh... shit you must be excited, hey. I remember when mine first rolled out in front of me. i had seen it before, in japan (bought it of my host family - exchange student) - but now it was MINE lol
hope it all goes smoothly with the compliancing, and yes, GET PICS!
i know man. how i wish the cars have the same std for around the world. save the trouble of getting compliance ETC. Yea i will try to get pics tommorow if i have the time cos the car is in williamstown so.
We are getting a student later this month. Have a shopping list th>>>>>>>>>>>>>>>>>>>>>>>is long.lol
ok guys im paying the rest pf the money to the lgistics people tommorow. Hopefully the car will be moved to the compliance center by this week. Will take pics if i get the chance.
so where are these pics then?
2 hours away!?@?#?@
im not gonna see it cruising around on a daily basis?
hhmmph..
yea i live 2 hrs away from melbourne in a little town called Toolleen very near to heathcote or shepperton though
Ok guys i got the car this afternoon.
Got to the freight fowarder and turn the ignition battery totally flat had to go and get a battery and a small jrry can to get some fuel. Anyway the freaking thingy its great!! :P . Its very sharp sterring and stuff. Going to send the car for compliance tommorow to Kamikaze motors tommorow morning. They will need it for 2 wks for compliance there. As for pics i will upload it tonite.
Im so pleased withe car!!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
