Chrome and Skylines don't mix...
But if you HAVE to, then go the race-style chrome.
Even better, get a polished wheel - shine without the added weight that chroming adds.
i have 20 x 8.5" wheels on my R33 GTS25t
front and rear guards have been rolled, tyres are 225/30/zr20
guards sit just on the rim, front and rear with only minimal rubbing at the front on hard lock.
Basically, 20s are so big, that it's almost impossible to keep the rolling diametre the same (on a skyline anyways).
19s are still really massive, if you really must go for big wheels.
Run it in a tyre calculator, but i have never seen any profile less than 30.
so your telling me my stupid 17 inch volk racing wheels r better
First of all work out what you want to achieve, looks (like I said chrome on sports are is bad, good for 4WD like in America) or power. If you have a massive FMIC and upped boost and 20 inch chromies... wtf are you trying to achieve? Its like a sprinter having a cigarette before a run...
If you want a nice modded car with nice wheels then get some smaller 18 wheels that are light weight... Im not asking you to get the super light type but something that doesnt weigh a tone... youll be amazed how slower sports cars go with 20 inch rims, esp chrome.
Make up your mind with the following pics:
Clearly chromes are suited for the 4WD!
Edited by Sir-D
Hell yea, gimme your volks :thumbsup:
Chrome is bad, but shadow chrome etc, the other forms that look fitting are nice...
There's a guy up the road from me with chromies on his monaro.. The entire rim is chrome lol, looks like a massive silver dinner plate.. it's ugly.
Don't put chrome near your car... unless its shadowcrome etc etc
And yea, 20's 19's even 18's are going to compromise your car's drivability and handling if not properly set up with the appropriate suspension...
... Dn't get chrome :
Massive chrome on skylines dont mix in my opinion, dont get me started on those vaults ones ahaha. Not only does huge chrome rims adds more weight to the car it also kills the comfort factor and tyres will burn a deep hole in your wallet. I rekon 17 18s light weight Jap rims are the way to go, suits the car more.
But hey if 20inch chormies float your boat Mario then go for it, its your car man in the end your customizing it to your liking not for others.
Edited by JUNR34
  • 10 months later...
I am Getting gianelle deep chrome dish jet black 10 spoke 20s i seen an r33 with the black car black wheels with chrome dish looks sexy...how often will i hav to change tires ?
that all depends on alignment, and how stupid you are with the car.
not often if you dont do burnouts and drift. if you do... you better have deep pockets :(
At the end of the day its your car and you should modify it to your tastes not others.. if your intending to do SHOW then by all means go 20", but if its for a street car go 18".
and tyre prices between 19" and 20" isn't much different either, so if you can afford the initial cost may as well go 20". You will need 30 series on the front and if you like 35 on rear.
Cheers
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
