echo AAARRGGHHH!
cat * | grep Topic Subscription Reply Notification
echo finally
rm -fr /
duude. you should start using a mail client instead of saving your emails as files :(
no no, that was in reference to ebola... he seems to be checking his email using a unix file structure :D
don't worry... unix joke.
  • Replies 89
fixed... fkn finally. stupid emailing script... had to hand trace the bloody thing. gaaah hate going thru other people's code.
added user group icons as well to forum display and profile display.
need some sleep now.
Umm shan you probably don't want to know this.....but emails are not being sent for all responses now, just some :P
check your subscription type. if you want email notification of all replies then make sure "immediate" is selected
  • 5 months later...
With the upgrade it looks like we've reverted back to the subject for email notifications no longer reflecting the name of the thread that it's notifying about.
Can this be fixed again? :)
BTW the update looks nice!!
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
