I *think* I have a faulty ignitor, the car's still running but drops to 5 cylinders occasionally, but before I go get a new one I'd like to test my theory.
Does anyone have a spare they could lend, or are willing to let me pop round, and nick theirs for half an hour?
Cheers,
- Ash.
https://www.sau.com.au/forums/topic/125181-short-term-borrow-r32-ignitor/
Mine occasionally drops a cylinder on cold start then smooths out, it also tends to drop a cylinder after a high rev and has recently started to sound like an ignition breakdown.
I've always assumed its the lifters pumping up but the cold start cylinder drop out has me a little confused. There's no tapping and what not so its not the lifter bleeding down.
Any of the above sound similiar?
You can borrow mine for an hour or so if you wish... The other side of town for you though I believe?
  • 4 weeks later...
Damn subscription business not working, I'd just assumed you'd all abandoned me to my fate (shold have known better), and shit i didin't realise I'd been putting up with this volvo crap for so long.
Okay, mine isn't on cold start, it's after the cars been running for 30mins or so it starts to play up.
The ECU is also reporting the Ignition Circuit error code.
Do those offers still stand fellas? I'm living just south of the CBD now so can head where ever really.
Lemme know if it's convenient for one of you this weekend.
Cheers,
- Ash.
Offers still up.
All though I've started to experience the odd pop myself. :D
Its fairly random but sounds very much like the start of a coil problem. :(
Give it a bit of stick through second one time its fine, the other i get a bit of pop pop pop pop... :P
No probs.. I missed the old mans call yesterday.
Interestingly I now no longer have what I thought was lifter pump up where after a hard rev it would drop a cylinder.
Instead it now has little pops through first, second occasionally pops and third & fourth never pops. :no:
As with a wot through third & fourth bring it hard up on boost in any gear with the foot on the brake and there are zero signs of ignition break down.
Who knows... Any way.. I'm stoked, It now pulls damn well to 6k where as before I was shifting up at around 5k in fear of what I thought was lifter pump up. <who knows> :D
Any time during this week is fine, I'm still a Uni bum so left me know when your available.
Just something to note guys, I wouldn't want to spend too much on a second hand ignitor, because there is a good chance that it will fail again in a fairly short timeframe, I've seen this kind of thing happen countless times.
If you don't want to risk having another failure, head down to petro-ject to get your's rebuilt (or if you're lucky you can swap it for one that already is). They put their own design circuit board with very robust ignition components in it & you get a 2 year warranty. It won't be cheap I'm sure (at least $300 like nisswreck), but if it does fail they will look after you.
My 2 cents
Edited by JazzaR33
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
