Heyy, Ive been having missfiring issues and all sorts of crap with my car since i got it
There fixed now but it lacks performance (after i got new fuel pump it was really quick for about 3 days, then i left it overnight and next morning it was slow) Basically at the moment boost kicks in at 3krpm and holds all the way to 6, no real pushback in seatage. It used to Die out at 4krpm then kick in at 6krpm alot. But for a while there(after i got new pump), boost was kicking in at 3, building then at 4 it really pushed u back into your seat and.. i want it to do that again.
Tell me if above isnt clear, ill re-write it
Anyway so here what ive tried:
Clean AFM with metho (was already clean)
Full ECU diagnostics (got code 55 which means all ok)
02 Diagnostics (light was on slightly longer than off, so its running pretty good, slightly rich)
Replaced Fuel pump with a walbro (old one wasnt flowing anywhere near enough) (helped with missfire)
Replaced Fuel filter
Ran some injector cleaner through
Regapped Spark plugs to .8m (helped finish off the missfiring prob)
Tested voltages on Coil packs, got from 1.3-1.9 so pretty normal, checked contacts to
Re-checked all intercooler hoses
Tried various Boost controller settings
Can any one suggest something else to try on it please?
(ive tried some other things but i cant remember em all)
Take the boost controller out maybe? At least it will rule that out as the source of the problem.
Go to a dyno day, for about $50 you'll get a much better idea of what is happening.
Hmm i dont think itd be the boost controller and its a pain to take out, but its a decent suggestion, when i get a spare 4 hours ill take it out. Such a fiddly device and enclosed space T_T
Erm any idea where to find out about these "dyno" days?
Its a standard ecu, and its running 10 psi atm, but makes no differrence if its on 12
Any other suggestions?
Edited by r32 gts-turbo
just a suggestion ry a different afm i don't think it's recomended to use metho to clean them.
hmm metho's not very harsh and doesnt leave residue, um i think phat32 used it so i stole his idea
Dunno where to get a different afm from, but tomorow ill open it up and check the connections. Any 1 wana lend me a afm? In melbourne area, ill come to your house try it on then bugger off :)
Fuel pressure ok? I mean.. if it was great one day, then bad the next, and that was after a fuel pump went in.... you could have a fuelling problem perhaps?
I dunno that a dyno thrash is a great idea if you have unknown issues. I guess it could finish the job and then you'd REALLY know what the problem is! ;op
Standard ECU eh? See if you can borrow someone's laptop and consult cable too.. it'll give you an idea of what your injectors are doing, and whether the ECU thinks you're lean or rich when you put the boot in. Might be useful.
The o2 sensor test isnt a good enough indication of whether the car is running rich or lean?
The fuel presure is cool since the new pump, he tested it all out again after the install so that couldnt be the prob
Perhaps a 14 second car does feel this slow, i dunno, but i swear its gotten significantly slower.
Its funny you should mention cam timing, because my mechanic said my ??VAC?? pressure was a bit low and that can be a indication of my timing belt being off by a tooth so.. Thats what he seems to think is the problem but well its not constant only happens sometimes so i cant see how it could be that.
The ignition timing is cool, he re-did it for me so no problems there
Some one else suggested a compression test to, but i need 2 people to do one unfortunately :)
Thanks guys
get it on the dyno, and get your fuel pressure checked. If there is a blockage, it would have killed the fuel pump both times, with the old one and the new walboro. im pretty sure there will be a blockage. I have seen this happen before, bits of the petrol tank or lines breaking down and getting caught in the lines. it will still run, and to someone who doesnt know the car, would have no idea, but it could be down 20rwkw or so on power aswell
nah no bov and no spiking
After the mechanic installed the walbro, he re-did the tests for puel pressure and said they were fine, but i suppose your right and something could have slipped off an old pipe or something. I dont know him very well and i know if i go back and ask for him to re-do the fuel pressure test, hell just laugh it off and ill come back with something else new so.. Is there a tool or a way to check the fuel pressure?
well yeh i have done that (unplug battery, press brakes, left for some hours) but from what i know it makes very little difference any way
Any1 else?
weird, my car runs like a non turbo for around 15kms untill it relearns all the fuel maps etc then its a rocket again for a few more months till i have to do it again..
im stumped. sorry
im stumped. sorry
Its definitely impossible as the r32 and r33 ecu's don't learn anything to do with ignition, afr's or where detonation occurs. Its not within their capabilities.
All they do is sense detonation pull timing and drop a little added fuel in at that given time, it doesn't remember anything.
I had mine on the dyno some time ago when I had the stock ecu running ~1bar, did back to back with an ecu reset, zero difference.
Took it to doctor drift friday night (felt a lil weird rocking up to a r31 skyline club do in a 32 but meh) and got it dynoed. Put out 135.8 rwkw and the doctor drift bloke who did the dyno said theres nothing wrong with it or the performance, so im just tripping out i guess hehe. Oh well, i got a quote on a 33turbo install.. Cheap + he rkns 30kw's is pretty easily attainable so allll good :(
Post the dyno sheet. If its dieing off after 4k and then picking up after 6k it will reflect.
But your right.. I remember when mine was making 140rwkw or there abouts.. It felt slow. Only when it started cracking 160rwkw did it start feeling decent.
Be aware dyno's read differently but mine at 12psi (stock ecu, stock IC, 3" exhaust) made 152rwkw with ~11.5:1 afr's.
100% stock on the same dyno it made 115rwkw.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
