Yeah,
Bayside Blue is by far my favorite color for the R34 series and it certainly is eye-catching. It took me ages to find a GT-V in that color. (they're quite rare and the color is in demand) Like I said, it was mainly the GTR's that were available in B-Blue, which works in my favor - most people seeing my car for the first time (or driving past me) think it IS A GTR, just because of the color!:P:(
Of course, anyone with even a little bit of knowledge about Skylines will pretty soon spot that it isn't a GTR, but still...
BTW - what is SAU? If you're refering to the forum, then I found it by following a link on the British GTR register (I'm a Brit living in Japan)
The Kakimoto is a great exhaust. It is a special version for N/A. It doesn't drone that much, but it can be a little loud (though its a matter of opinion), so I usually drive around with the extra baffle fitted in the tail...
Cheers
Dave
  • Replies 116
damn im determined 2 make my next skyline that colour!
Yep SAU is the forum it stands 4 Skylines Australia
Do you hav anymore info on that exhaust? im looking at changing mine and yours sounds pretty good ive heard of kakimoto before but i dont know where i can find kakimoto stuff???
  • 4 weeks later...
Originally posted by neoGT-25
Hey Nismodified, why are you buying a jap brand cat?
isent it cheaper to get a localy made item?
id love a A'PEXi exhaust system tho... but short on funds :D
Also... how many of us here with N/A lines have a jap exhaust compared to a localy made exhaust? also... what size are they? im getting a 2.25" front to back... is this a wise choise?
I got a catback lukey muffler and it makes the sweetest sound, i hate big bore cannon mufflers, they SUCK. and yeah why get a jap exhaust when the aussies make tough exhausts that make superb sound. mine is 2.5" i think, thats what the standard muffler was connected to as well form the extractors
i went for jap, because im a bit paranoid about making sure i get some power from the exhaust.
nothing in life is certain, but at least using jap settles my nerves a bit.
any way, i bought a 2nd hand jap cat for a good deal off a mate.
If i had a turbo, i wouldnt worrry as much about where to get my exhaust done.
currently, i have on a 2 3/4" 5zigen, it has a muffler as big as the stock muffler, one resonator. 3.5-4" tip.
very nice grumble while driving along, dead shit quiet after 3000rpm and at idle.
drony at 1900rpm-2900rpm
power seems to pick up well at about 4000rpm, it took me awhile to get used to the noise but i love it !
  • 4 weeks later...
I've got a R32 GTS25 2 Door...
2 1/2 inch exhaust with Kobe Extractors and resonators
GTSt 'Type M' Brakes (5 stud conversion) 17" Wheels
GTSt Viscous LSD
Currently fitting side skirts, and tossing up between putting a RB30 bottom end, or a RB25DET to get more horsepower
Currently 150kw at the engine
Originally posted by Nismodified
kobe extractors? Was that locally made or is that a Japanese made unit?
if you do proceed with the Rb30/rb25t conversion, i am very interested in purchasing your extrators.
I bought them from NZ, and put them on 3 months ago. I've been stoked with them. To be honest I wasn't expecting a noticable improovement, but the torque increase is great. I will be happy to palm them off to you, when I go ahead with the RB25DET conversion.
  • 4 weeks later...
Guest R33Glenn
lolzz...nismoman18, the nissan designers must have a short memory span, and your R33 looks dam sweet! talking of things in the boot compartment, i found some small Japanese fireworks and a old japanese lolly wrapper this morning, would of gave me a dam fright if those fireworks went off some how :P
with the badges, i also have red ones, i heard that i was sposed to have blue badges so i dunno..,. Also i was talking to someone about the battery thing and apparently its for better weight distribution (spelling) but i cant see how the weight of the battery could effect the handeling that much..... but yeah either way.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
