exekiel what are you using to stop detonation? you say your using pump are you also using methanol/water injection? sounds like allot of boost for 10.2:1
no methanol injection. no water injection. just fuel and air mate
my point is ... static compression has SFA to do with how much boost you can run
or how about one of the other cars ... 9.5:1 and 14psi ... and the only reason why it wasnt pushed to 20psi was because of factory valve springs being weak as piss
  • Replies 53
Because NA engine arn't designed to run boost, hance the higher compression on NA engine. Put some positive boost into the old girl, and you'll end up splashing all your oil and a piston or two on the road.
If you were to run positive boost on an NA engine, it would be wise not to go above 5psi, though running that little boost would decimate most turbo's cause of the already high compression from the NA engine.
If your interested in running boost, if would be best to purchase a decompresion head gasket (possibly copper, but not always) to run anything over 5psi.
On that note, running 5psi on an NA engine, and driving her hard all day, you'd end up pushing out a few pistons onto the road again. so you have to be careful. Some engine are different to others though, so if you dont try you'll never know!
WTF? I was aiming for REAL results. Back up your 5psi max theory.
Cause I just posted that I have been driving around in my SR20DE+T with 9psi (which spikes to 12 or so) for at least 6 months. Its been kicking around for over 12months as it is though, I bought it like it is. Previous owner drifted it regularily.
This NA-T car has been my most reliable car yet. More so than the 3SGTE Celica and FAR more so than my R32 GTR, both of which were running close to stock boost on engines that were "MEANT" to be boosted.
Now REAL results anyone???
mmmmmmm boost. Just make sure you don't drive it too hard :(
The VLT (RB30ET) doesn't run oil squirters......
I'd say 400rwhp is pushing near the limits of any RB. The Rb30's tend to have issues with much over 450rwhp, all though they have been known to hold together under street driven conditions at close to 500rwhp. They do run less rod angle than the rb25/26's so this may have some thing to do with it.
so u got it back then dan?
some people dont know what they ar talking about :)
one of the main things that limits compression ratio is the quality of the fuel
you wouldnt want to run 91RON on a 10.2:1 engine cause she would be pinging like a bitch (thats what ive seen - although hondas are pretty high comp, but i think they need premium??)
and that is especially important on a high comp turbo engine
with the turbo forcing compressed air into the piston increasing charge density and the added affect of the high comp, 91RON wold kill it, 95RON or even 98RON would be best (you can buy high comp v8 crate engines running 12:1 comp - but they have a warning not to run pump fuel unless its like 100RON or something - but only in america :P )
that is why typical turbo cars run lower comp than there n/a partners so that the added affect of the increase in charge density doesnt require a different fuel (lower comp, higher charge density allows the same fuel as a higher comp lower charge density essentially)
there is nothing wrong with decent boost on high comp as ezekial and cubes were saying - as long as your fuel is good quality and the setup is able to handle it
as ezekial said the only thing limiting the boost was the springs
wnat more boost - upgrade springs
my 2cents :D
PS thought there is nothing wrong with high comp lowish boost mmmmmmmmm :D
would sound very very nice
Amen to that = P
Turbo chariging my 96 NA GTS4 in 2months at boostworx. It be running 10:1 comp with about 5-7psi of boost, the mechanic said with good tune it be possible to run 12psi(but that requires more $$$$ > < or engine go BOOM)
. About 50% increase in power he said. If standard turbo ECU wont work he said he Remap my current Ecu.
Btw guys, My rides auto -_- (yeh yeh i know, not many gts4 came out in man). Is the Na gear box handle powerincrease? Im changing to a GTR gear box at the end of the year when i have enough mumbo $$ ^ ^ .
4wd trubo = )
NA-t all the way lol
Edited by shorty_01
Nah the pics were from when it was sitting at AAMI...they wanted $15K buyback for the wreck....so just took the full payout and bought my GTT <====
I think the stock turbo ECU will be fine for what you're doing, the timing and fuel is fairly conservative, so may match up with the high-comp turbo setup extremely well. Good luck!!!
The trick to running a high comp on pump fuel is to ensure there is minimal back pressure. Correct turbo selection.
The reason big turbo's make more power on the same boost level has everything to do with uncorking the hot side allowing the motor to expel its gas much easier, as there is less back pressure much less of the nasty hot already burnt charge sits around in the combustion chamber waiting to 'dirty' the new clean charge.
So
less back pressure = better cylinder filling = bigger bang
less back pressure = less dirty charge left behind that contaminates the new charge, the contaminated new charge is heated and as a result either less ignition advance needs to be run or a higher grade fuel used.
A GT42 running 20 odd psi on an na 10.2:1 bottom end is quite possible. Thats not looking at large cams that bleed off cylinder compression and once again improves ve (cylinder filling).
A stock turbo with a steel wheel pushing 20odd psi. Not likely. :wave:
shorty, I'll be keeping an eye on how you go down boostworx. Shall be interesting. What turbo are you running?
Hey cubes,
Running Standard S2 turbo.
Im not sure if its boostworx now because adel turbo tune (south Rd) offered me a cheaper rate.
6psi seem to be safe boost level with standard intercooler. Front mount i can boost to further.
AT the end of the day shaun from boostworx n mark from turbo tune concludes by saying its all about tuning ie. Ignition Timiing etc.
Yeh ill keep u guys posted. Conversion be completed 31 sept (thats when i have all the mumbo $$$)
BTw people just to let u know about H2P insurance (in conjunction with RAA). Theyare cheaper then Just cars etc and many others. Im currently P plator n drive na GTS4. Compre insurance = 1g. I contacted them 2day saying im modifying my engine eg turbo. Asumming my preimum will go up in the hundreds... suprisling it was $0.00 (any mods under $4,000g doesnt affect). They were nice people n knew about skyline etc... lol. Give them a Try.
Edited by shorty_01
Shorty, if I could suggest one thing. Seriously consider one of the sliding performance high-flows, at under $900 it would be awesome on the high-comp engine, plus you'd bennefit from the much larger, better flowing exhaust side. You could sell your S2 turbo to cover most of the cost.
If I had my n/a + t experience again, I'd do this no questions asked!!!
I've got this turbo on my car at the moment and think it's great with 9:1 compression :D
So
A stock turbo with a steel wheel pushing 20odd psi. Not likely. :D
now you're talking
my example is the VH45 engine ... and yes i have large cams but i'm only going to use them IF i need to effectively bleed off some compression
for the mean time i can use the motec to switch vvt off (push inlet closing out 20 degrees LATER) once it reaches a certain boost level which will cause detonation ... its going to take some time to get it right but will be interesting none the less :P
Aswell as, if you were to turbo your car (In QLD anyway) you have to upgrade the brakes to the right size, for eq; Id turbo my Silva (Rb20DE) Id have to upgrade to the R32 5 stud brakes to comply with ADR rules, and be able to get it mod plated for the turbo.
On top of that, The gearbox would need to be replaced, and the dif. After driving it around for a while, you'd end up blowing them both.
Its cheaper to just buy a factory turbo, and not bother turbo'ing an NA car.
On top of the turbo, you have;
Dump pipe,
intercooler piping
exhaust,
brakes,
steering alignment,
wheel alignment,
wheels, :wave:
gearbox,
tailshaft (If need be)
diff,
Hicas,
ECU,
wiring loom,
plugs,
injectors,
fuel pump,
probably a fuel regulator,
compliance and,
Mod plates.
Its really not worth it in my opinion!
Mate WHAT THE f**k??
Did u just blurt out everything uve been told by mates or some shit??
For starters any engine can handle positive boost as long as it is setup correctly and in the hands of tuner that knows what he is doing.
Perhaps you would like to have a chat to my NA engine running 10.5:1 comp on 12psi thats making 300+ RWKW and tell it that it should have left a piston or two on the road... WTF... seriously mate dont spout shit if you have no idea what your talking about.
As for upgrading brakes there are ways around that with QLD main roads ADRS, something along the lines of adding a bigger engine or turbo, the car will require 4 wheel disc brakes.... that is all.. so i would talk to your engineer or do a little more study aswell.
Sorry for the rant but i hate that...
The Action Begin in 2 weeks :(
im going to have to stick with my NA 2.25 inch exhuast with cannon but installtion does inc Front n dump. Just no money for good exhuast yet :|
666DAN ,
Did your car drone when u had turbo put on due to NA exhaust or was it mellow?
I got a silencer on my car atm... taking it off it horrible :D bloody droony :O
Edited by shorty_01
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
