Will be very interseted to see how your kit works out. If you have any problems or if all smooth sailing.
I don't expect to see my kit for about 3 weeks so I have time to upgrade the fuel pump, injectors, AFM, front pipe and dump pipe, intercooler, air box, brakes and coil overs.
I will let you all know how how it comes along..
:wave:
  • 4 weeks later...
  • Replies 121
Yeah well I'm in the same boat too but I ordered the HKS GTRS. It should be here sometime this week from nengun. Could be a few weeks yet till I can install it but it should be a well worth the wait.
Any news on your setup? Results, whether you have cam gears etc?
Thats why i was asking. Also do you have a cat, and what brand and diam is the exhaust?
nah, no cat and like i said i just got a new custom exhaust (cat back) 2 months ago, its 3inch, 1 centre muffler and last 50cm is 4inch :rofl:
Sam reckons that cam gears will make a big difference in boost response, so i'll be getting a set soon....
you don't have a cat either do you?
I have a catalytic converter, a 3' Catco. I take it out for track work, but hasnt been back in since Dutton. Only takes 10 minutes and 4 bolts. Keeping killing gaskets though changing it in and out all the time, need new gaskets for when i put the cat back in otherwise im going to have a leak:(
Ok, so the breathing on your engine was pretty on the money then. Was thinking more and more about it last night...i dont think i want to get rid of the RB20+TD06 combo. Its too good value :rofl:
Well the turbo is on and i coldn't be happier.
As for results I really haven't had alot of time to do much since I ftted the turbo and at the moment I am trying to sort out rego changeover from QLD to NSW and the car goes in shortley to sort out a pod filter box/partition and a blueslip etc. :rofl:
The boost starts round 2 k and full boost is around 4k but the tune is a little lean between 2.5k and 3.5k so the turbo isn't comeing on as quickly as it can(old tune for old ITS turbo). Top end is not bad I can say.
Once that is all sorted I'll organise a dyno run for a couple of 15psi and 20psi runs.
Have no idea on what the results will be like to be honest.
In my opinion the HKS GT-RS a perfect upgrade for the RB20.
For 2.6k delivered you cantgo wrong.
So yeah sorry I can't help ya's out much yet. :D
..i dont think i want to get rid of the RB20+TD06 combo. Its too good value :D
after last night, i don't think you can really get any better package then what you already have for a RB20 :rofl:
244rwkw with response of a GTRS is pretty much as good as your gonna get.....i mean without going the rb25 route, you will have to spend alot of $$ for not much more gain.....however, some nice 264 cams would no doubt make things interesting :D
Ok, so the breathing on your engine was pretty on the money then. Was thinking more and more about it last night...i dont think i want to get rid of the RB20+TD06 combo. Its too good value :P
I remember Sydneykid saying that a straight pipe makes up to 10rwkw more than a gutted cat , because the flow is straight instead of expanding into a chamber and then narrowing back to 3"......
hmm, maybe i need to try straight pipe :sorcerer:
Ive paid for the cams, should not be too far away, but i dont think i want to spend the money on getting them installed and the car tuned, Thats over $1000 put towards better things, like hookers.
Though if i can get a good time at Sandown next year, it will be tempting to front the cash for install, good fuel and 1,6bar and a tow home :P Piss funny if the little girl can keep pace with some of the more powerful cars.. (I am dreaming :) )
The real surprise is at 4,000rpm you have about 100rwkws and i have 135rwkws. And my peak torque is 506ft.lbs at about 4,900rpm but you make your peak torque of 416ft.lbs at 5,400rpm. It would be interesting to see the torque curves, mine is making a boat load more torque a lot earlier.
...did i say get some cam gears and dyno time :cheers:
So much for Greddy turbos being old truck turbos :cheers:
do it :P
this thread has been pretty interesting
the GT-RS definitley looks like a good upgrade
I'm currently using a td05h 16g, but i want to upgrade to something ball bearing in the future
i was thinking either the 2871r/26r or the 3071r
ive heard lots of bad things about the 3071r though, something about the exhaust housing..?
Just pay a bit of money and get your TD05 high flowed with a 20G compressor :P
THe td05 compressor housing is really ineffecient though
i'd need to get an 06 comp. cover
and in the end its still not ball bearing
although, the results your 20g has given give me a lot of faith in the greddy/trust turbos
meh to ball bearing. There is much more to them. HKS rate it at 400ps, Greddy the 20G at 420hp. And the 20G is (in this case) more responsive making power sooner. The boost plots are basically the same, but the actual torque and engine power is better with the 20G. Explain that???
According to HKS USA
HKS GT-RS - 400 PS Output
COMPRESSOR:
-Wheel- 52 Trim - 51.2 Inducer / 71.1 Major
-Housing- 60 Inlet / 50 Outlet - 0.60 A/R
TURBINE:
-Wheel- 76 Trim - 53.8 Major / 47.0 Exducer
-Housing- GT25 inlet / Internal GT25 outlet; 0.64 A/R
Greddy TD06-20G - 420hp Output
COMPRESSOR:
-Wheel- 60 Trim - 52.6 Inducer / 68 Major
-Housing- TD06 housing
TURBINE:
-Wheel- TD06S6 Trim - 65 Major / 55.1 Exducer
-Housing- TD06S 3 bolt 8cm
So for some reason the wheels in the 20G just get the job done :P
? easy.
-your using 3psi more than me.
-your a/f ratios are far leaner than mine, you had close to 13:1 afr.
-External gate will always make more power because of less restriction
-you have tuned lenght s/s manifold. and i have stock cast.
-you have properly tuned cam gears...
& even in rwd my gts4 will have more drivetrain loss than a true rwd.
that will account for more kw than the actual turbo sizes. :P
All good points, but im not talkign about peak powre. I will be interesting to see if cam gears can pick you up 35rwkws in the mid range and get you almost 100lb.ft of torque a few hundred rpm earlier.
Peak power im not too fussed about. If you wound your boost up to what i run you woudl have bagged in the 230+.
Just trying to make the point, the response of a turbo has more to do with wheels etc etc then whether its ball bearing
35rwkw! haha no way, if i get an extra 10-15rwkw i'll be more than happy :P
The main thing is to get boost sooner....
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
