I tried to put in my intercooler today and managed to remove alot of skin from my knuckles.... and thats about it.
My 32 has the active front spoiler which is fitted to the exact place my cooler bolts onto. To get to the bolts on top of there mount you either have to remove the headlights or remove the front reinforment bar. Both kicked my ass :(
The nuts that hold the headlights in from are hidden behind a few hoses that can't be moved easily and I can't fit a tool in there. The front reinforcment bar is held in by 2 big bolts and 2 nuts. I got the bolt off one side easy enough but couldn't get the damned bolt off. I tried covering it in RP7 and left it a atleast an hour and still no luck.
Anyone know of a way I can get them off?
It'd be a very straighforeward install if I could remove the spoiler motors :wave:
or is there someone I can take it that'll give me a hand (and has the right tools)? I don't really wanna pay someone to do it all for me cause I want to learn to do things for myself
Cheers
-Matt
im not quite sure what ya talkign about but i had troubles getting my bumper off the intrution bar that was held by 2 plastic clips.. so in the end i just took it all off and once off the bumper was soo much easier to take off.. i didnt have to take off my lights or anything
oh sorry, intrusion bar = reinforcement bar
I wasn't exactly sure what it was called. I got the front bumper off easy enough, but the intrusion bar didn't want to come off. Theres two pieces of metal coming down where you driving lights mount to, the front spoiler and its motor's etc are mounted to the inner side of that. They have bolts that hold them on from the top of that bit of metal which is under the headlight.
If I can get the front spoiler motors off I would be set
I've taken off a few r32 bars/headlights/reos. The trick is you have to use the right tools.
when you said you can't get a tool in there, what are you trying to get in there? a spanner? some bolts can't be reached by the spanner.
also, a 1/2" ratchet and extension might be too big.
I also have a 1/4" socket set for fitting into those tight areas.
taking the bar off is a piece of cake. same as headlights. same as reo.
I've never seen that active spoiler thing, but I suppose it'll have to come off anyways for the fmic. Even if it didn't, they're pretty gay. Just rip that off if it's in the way.
Ok, let me try and explain how to do it.
Take the indicators out. It's like one screw. then just pull it.
take the wheel arch plastic off first. If you can't remove the clips easily, just break them. you can buy new ones from autobarn for like $2.
Then take the bar off. you dont' ahve to take the headlight off. There are bolts under the wheel arch plastic. and bolts where the indicator was.
the motors shouldn't be in the way, because the bolts you need to access to take off the front bar are no where near there. Secondly, you can't get off the reinforcement bar without first taking off the front bar.
ther eis no need to take off that reinforcement bar. cut it on the car. easier. but if you want to take it off, it's only 2 bolts. they're not very tight either.
Follow these instructions and you won't have any troubles. If you do it like this, the job will go from being a 10/10 like what you thtink it is now, to a 1/10.
Cheers
Edited by 97r33gtst-typeM
lol umm... I got the front bar off no problem
The reo and headlights is what I can't get off. The reo is held is by a bolt and a nut on each side. I got the bolts out and the nuts wouldn't budge so the reo wouldn't slide forward. I tried a spanner and my little socket set with no luck.
The headlights were even worse. I took the battery out and got the nut sitting under the what I think is a power stearing line. Further down is another nut but its stuck behind a solid pipe that isn't gonna move in a hurry. I could barely get a finger to it let alone a tool.
Cheers for your help
Success!
I bought a socket adapter that let me use my big wrench and got the sucker off. With a bit more swearing and skinned knuckles I finally got it on. The reo isn't sitting perfect yet and I ran out of daylight to cut the front bar but its all good sofar.
If you have a active spoiler you have a up/down button on the left of the driver. I think you have to have the hand brake on before it'll work manually for some reason. Mine was pretty loud, you could hear it over the radio if it wasn't turned up alot.
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
