  • Replies 219
so had the cam gears being dispatched out yet?
Yes, most, just be patient, like i said all will be recieved no later than early next week.
I have to jugle work and this.
thanks bnuddy!
got my cam gear today!
sorry about the post i made a few days ago.
im as happy as larry now!
and people to assure you, they are of very high manufacturing quality!
im very pleased with the cam gear in (blue) that i received, i will keep you posted as to how this cam gear tunes up!
im hoping it will be fine! looks good to me! but we will find out in the next few weeks i guess! dyno rebroad minded persons will prove it or not!
im hoping this will give me another 20rwkw - thats the plan anyway!
so im hoping for a lazy 220rwkw - power fc, pump, 14psi, dump + 3inch exhaust, FMIC, filter, fuel pressure reg!
thats the plan!!
thanks again r33kid, very happy with the product!
cheers
Giffo
just one query, i wont be posting anymore about when its arriving or whateva,
but are these being sent by courier, cause if they are then they wont send to my post box, as i have found out with other stuff.
if not shes all sweet,
please let me know if its courier
Got mine today as well, took me no more than 2 hours to get them on, set it +3 inlet, -5 exhaust (crank), noticable difference seat of the pants, will get on a dyno next week.
kjb_r33 -- you in sydney??
Which car did you install this into.. hope the car with an rb25 in it lol..
What should my settings be??
Yeah, penrith, was a 32 with a rb20
Will be worth while for the cost but as you obviously have a upgraded turbo a set of tomei poncams would give you better gains. but this would be a lot more expensive than a cam gear.
cheers
So whats the difference between gains with either an exhaust camgear and poncams?
Whats better on spending money on?
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
