  • Replies 219
so had the cam gears being dispatched out yet?
Yes, most, just be patient, like i said all will be recieved no later than early next week.
I have to jugle work and this.
thanks bnuddy!
got my cam gear today!
sorry about the post i made a few days ago.
im as happy as larry now!
and people to assure you, they are of very high manufacturing quality!
im very pleased with the cam gear in (blue) that i received, i will keep you posted as to how this cam gear tunes up!
im hoping it will be fine! looks good to me! but we will find out in the next few weeks i guess! dyno rebroad minded persons will prove it or not!
im hoping this will give me another 20rwkw - thats the plan anyway!
so im hoping for a lazy 220rwkw - power fc, pump, 14psi, dump + 3inch exhaust, FMIC, filter, fuel pressure reg!
thats the plan!!
thanks again r33kid, very happy with the product!
cheers
Giffo
just one query, i wont be posting anymore about when its arriving or whateva,
but are these being sent by courier, cause if they are then they wont send to my post box, as i have found out with other stuff.
if not shes all sweet,
please let me know if its courier
Got mine today as well, took me no more than 2 hours to get them on, set it +3 inlet, -5 exhaust (crank), noticable difference seat of the pants, will get on a dyno next week.
kjb_r33 -- you in sydney??
Which car did you install this into.. hope the car with an rb25 in it lol..
What should my settings be??
Yeah, penrith, was a 32 with a rb20
Will be worth while for the cost but as you obviously have a upgraded turbo a set of tomei poncams would give you better gains. but this would be a lot more expensive than a cam gear.
cheers
So whats the difference between gains with either an exhaust camgear and poncams?
Whats better on spending money on?
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
