grrrrrrrrrrrr
the guy from VDO emailed again, and even with the nissan part number that i gave, he still says there is no VDO item!
I gave him the part number that was in the aus300zx.com website to see if he has that in his stupid computer. i have no idea why its not coming up as a listing...
will keep you posted.
Warren
ok more bad news..
the moron at VDO who is emailing me, still insists they don't have a OPS for us
he won't confirm that the 300zx sender works at all.. he is dodging the question coz he is a f**king moron
i'll have to do some more searching i think
is it 100% confirmed that its the same sensor for 300zx/R32/R33??
what about any other nissans
thanks
Just some observations that might help:
1. Genuine OPS from Nissan is around $150 (trade....add maybe $20 for retail).
2. OPS PN is 25070-30P01 (R32 GTR and GTS4, R33 RB25DET and Z32 300ZX). FAST does show an alternate number for some models (25070-55S60), but it also shows the -30P01 as the direct alternative.
3. The VDO OPS shown on the 300ZX link looks identical to the type fitted to local spec R31 Skylines (RB30) as standard. VDO supplied some parts for Oz spec R31's, inc the instrument cluster and some other sensors, basically to build up local content. Be warned that quality is not great.
well spokt to some people who have done this on their 300zx, and they have confimed that te unit does work fine, but still suffers from the same problem as the stock OPS
this leads me to believe that the problem is not the OPS unit itself, but something aboutthe way it is mounted or connected
there's nothing wrong with the stock OPS...
the only thing wrong with them is the fact that they're getting close to 15 years old and as such, are f**ked.
what happens is the rubber seal around them fails, and lets oil inside the unit itself.
from what i've heard, if you replace it with another factory one (or in this case a VDO one) it should be fine for another 15 years.
*note* this is what i've been told in terms of why they play up etc
well i have spoken to a good mate who is a member of aus300zx.com
he said he changed to the VDO sensor and it failed in 4 months
then he changed to the stock sensor and it has been ok for about 6 months so far
BUT.. he did some kind of electrical modification to the OPS before he putit back on
apparently (according to him) there's 2 plugs on the OPS, but the stock wire only connects to one of them
He grounded the other plug to the chassis... and he hasn't had a problem since...
apparently an autoelectrician told him to do this
I want to try it out, but haven't had time to try and get to the OPS
  • 4 years later...
Hardcore thread bump.
Has any one used an aftermarket oil pressure sender to replace the factory unit?
I want to wire in an aftermarket oil pressure sender into the Vipec as a fail safe (if it sees less than 5psi to shut the engine down) but want to do it with a new oil pressure sender as my stock one acts up.
  • 4 years later...
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
