I know this was discussed at length when the forum was a baby, but can we do away with pictures in sigs again?
They may have been turned on by accident with the new server, but big pics of skylines and half-naked chicks make browsing SAU surprisiningly work unfriendly.
https://www.sau.com.au/forums/topic/12657-pictures-in-sigs/
Duncan, it was discussed recently and a decision was made to turn them on.
I agree, i don't like them either (not for the work reason - but the time they can take to load).
For this reason (ie dial-up) we will not be allowing huge ones...the size of meggala's or dark's is a good guide. Anyone with huge ones, or half-naked chicks will be asked to remove them. They're supposed to let ppl express a bit of individuality to their posts - not take up half a page or be pornographic! ;)
As Dox said, there is an option in your user CP to turn them off, if u need to :(
https://www.sau.com.au/forums/topic/12657-pictures-in-sigs/#findComment-238949
Thanks guys....just to clarify, I can see options to:
Show user's signatures in their posts? yes no
Show user's avatar in their posts? yes no
So, I should turn off all sigs to get everything back to normal? Or is there a way just to stop the pics?
Thanks.
https://www.sau.com.au/forums/topic/12657-pictures-in-sigs/#findComment-239197
Hmm currently I can only turn these annoying sig pic off with user cp->edit option and set "NO" to Show image attachments and code in Posts.
Just means have to click on the picture to see it instead of showing up in the thread.
Can't always have anything I guess :D
https://www.sau.com.au/forums/topic/12657-pictures-in-sigs/#findComment-256145
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
